Results 1 to 7 of 7
Thread: Need to know the best way to remove the oil pan?
    Jul 2009
    Central Alta Canada
    Default Need to know the best way to remove the oil pan?
    Hello, new guy here, I need to know the best way to remove the oil pan. Is it buy taking the motor out? Or dropping the front end? Let me know. You can contact me at sgoodhope@hotmail.com
    The stamped-steel pan comes off pretty easily, but the aluminum crankcase is a bit more work - in the truck. If you expect to do more work (i.e. remove connecting rods, oil pump etc.), removing the engine might be a better option.
    Jul 2009
    Central Alta Canada
    Default One big headach
    Hello again, I now have the trans pulled away from the block. Just getting ready to go and drop the 2 bolts holding the upper pan in place. I guess I will just have to figure it out along the way. Replys are slow and not very forth coming. One thing that would be nice to know is what is the torque spec on the piston rod bolts. I will post again after the job is done to let everyone know how it went.
    Mar 2007
    Pacific Northwest
    What are you doing? Inspecting or replacing? Bearings usually aren't a problem on the DMAX engine. I personally have seen LB7 engines go 300K.
    Anyway, torque specs for the LB7 is::
    Well........... sorry, I just tried to look up the specs on the GM SI website. The website is currently down? I will try again later for you.
    Jul 2009
    Central Alta Canada
    Default Bad injector leads to # 3 cylinder melt down
    My injectors started to go. I took it to GM. They ran there diagnostics and found that the right bank was running a return rate of 61ml and the left was 42ml. They replaced the injectors and buttoned it back up. When running the truck for the first time they noticed a miss. Pulled the glow plugs and did a compression test. All cylinders were at 390f/lb except # 3. It was dead. They called me up and said do you have 5000.00 so we can fix your truck? I said I will do it myself. Right now I just have a fuel line to remove and a few motor mount bolts and the motor will be out of the truck by noon. I already took the head off and it has been repaired with a new valve seat and valve pluse a 2thou decking to make sure it seats on the head gasket the first time. Now I have to pull the piston and replace it. It is toast. Luckly there was little to no damage to the cylinder it self a light hone should do the trick. Once I have it back together I will run a compression test on it before I install the glow plugs to make sure I have good pressure on # 3.
    Mar 2007
    Pacific Northwest
    Well then you need LOTS OF TORQUE SPECS! If you are going to mount the engine to a stand, you need to remove the rear aluminum flywheel housing.
    QUOTE FROM GM SI::::::::::::::::
    Caution: Do not mount the engine to a engine stand by the flywheel housing. The aluminum flywheel housing is not designed to support the weight of the engine when mounted to a typical rear-mount engine stand. Mounting the engine stand to the aluminum flywheel housing may result in engine damage and serious personal injury.
    Fastener Tightening Specifications
    Application
    Specification
    Metric
    English
    A/C Compressor Bolt
    50 N·m
    37 lb ft
    Air Cleaner Outlet Duct Clamp
    8 N·m
    71 lb in
    Air Conditioning Compressor/Power Steering Pump Bracket Bolt
    46 N·m
    34 lb ft
    Battery Cable Bracket Bolt
    12 N·m
    106 lb in
    Battery Cable Bracket Nut
    8 N·m
    71 lb in
    Bypass Pipe Bolt
    21 N·m
    15 lb ft
    Camshaft Gear Bolt
    234 N·m
    173 lb ft
    Camshaft Position Sensor Bolt
    10 N·m
    89 lb in
    Camshaft Position Sensor Exciter Ring Bolt
    9 N·m
    80 lb in
    Camshaft Thrust Plate Bolt
    22 N·m
    16 lb ft
    Charged Air Cooler Bolt
    21 N·m
    15 lb ft
    Charged Air Cooler Clamp
    8 N·m
    71 lb in
    Connecting Rod Cap Bolt - Angular Tightening Method
    1st Step 64 N·m
    1st Step 47 lb ft
    2nd Step 30 degrees
    2nd Step 30 degrees
    3rd Step 30 degrees
    3rd Step 30 degrees
    Coolant Pipe to Water Pump Nut
    25 N·m
    18 lb ft
    Cooling Fan Pulley
    41 N·m
    30 lb ft
    Crankshaft Balancer Bolt
    1st Step 100 N·m
    1st Step 74 lb ft
    2nd Step 105 degrees
    Crankshaft Bearing Cap Bolt - Angular Tightening Method
    1st Step 98 N·m
    1st Step 72 lb ft
    2nd Step 132 N·m
    2nd Step 97 lb ft
    3rd Step 30 degrees
    3rd Step 30 degrees
    Crankshaft Bearing Cap Side Bolt
    78 N·m
    58 lb ft
    Crankshaft Position Sensor Bolt
    10 N·m
    89 lb in
    Crankshaft Position Sensor Spacer Bolt
    10 N·m
    89 lb in
    Crossmember Bolt
    100 N·m
    74 lb ft
    Cylinder Head M12 Bolt - Angular Tightening Method
    1st Step 50 N·m
    1st Step 37 lb ft
    2nd Step 80 N·m
    2nd Step 59 lb ft
    3rd Step 60 degrees
    4th Step 60 degrees
    Cylinder Head M8 Bolt
    25 N·m
    18 lb ft
    Drive Belt Tensioner Pulley Bolt
    41 N·m
    30 lb ft
    EGR Bolt - California Emissions
    20 N·m
    15 lb ft
    EGR Bracket Bolt - California Emissions
    20 N·m
    15 lb ft
    EGR Valve Nut - California Emissions
    19 N·m
    14 lb ft
    Engine Block Coolant Plug
    18 N·m
    13 lb ft
    Engine Block Ground Bolt
    34 N·m
    25 lb ft
    Engine Mount Through Bolt to Frame
    75 N·m
    55 lb ft
    Engine Mount to Block Bolts
    58 N·m
    43 lb ft
    Engine Mount to Frame Bolt
    65 N·m
    48 lb ft
    Engine Shield Bolt
    20 N·m
    15 lb ft
    Exhaust Heat Shield Nut
    9 N·m
    80 lb in
    Exhaust Manifold Bolt/Nut
    38 N·m
    28 lb ft
    Exhaust Manifold Heat Shield Bolts
    8 N·m
    71 lb in
    Exhaust Outlet Clamp
    15 N·m
    11 lb ft
    Exhaust Outlet Heat Shield Bolts
    8 N·m
    71 lb in
    Exhaust Outlet Pipe Bolt
    53 N·m
    39 lb ft
    Exhaust Pipe Bolt
    53 N·m
    39 lb ft
    Exhaust Pipe Bracket Bolt
    34 N·m
    25 lb ft
    Exhaust Pipe Clamp
    40 N·m
    30 lb ft
    Exhaust Pipe Heat Shield Bolts
    8 N·m
    71 lb in
    Fan Pulley Bracket Bolt
    46 N·m
    34 lb ft
    Flywheel Bolt - Angular Tightening Method
    1st Step 79 N·m
    1st Step 58 lb ft
    2nd Step 60 degrees
    2nd Step 60 degrees
    3rd Step 60 degrees
    3rd Step 60 degrees
    Flywheel Housing Bolt - Black Circle Mark
    80 N·m
    60 lb ft
    Flywheel Housing to Upper Oil Pan Bolt - Black Triangle Mark
    50 N·m
    37 lb ft
    Front Engine Cover Bolt
    21 N·m
    15 lb ft
    Fuel Block Bolt
    25 N·m
    18 lb ft
    Fuel Filter Bracket Bolt
    21 N·m
    15 lb ft
    Fuel Injection Control Module Bolt
    20 N·m
    15 lb ft
    Fuel Injection Control Module Bracket Bolt
    21 N·m
    15 lb ft
    Fuel Injection Control Module Connector Bolt
    10 N·m
    89 lb in
    Fuel Injection Control Module Connector Bracket Bolt
    21 N·m
    15 lb ft
    Fuel Injection Control Module Cooler Eye Bolt
    27 N·m
    20 lb ft
    Fuel Injection Pipe Nut
    41 N·m
    30 lb ft
    Fuel Inlet Pipe Bracket Bolt
    21 N·m
    15 lb ft
    Fuel Pipes Bracket Bolt
    25 N·m
    18 lb ft
    Fuel Rail Assembly Bolt
    25 N·m
    18 lb ft
    Fuel Rail Connector
    45 N·m
    33 lb ft
    Fuel Return Pipe Eye Bolt - Cylinder Head Side
    17 N·m
    12 lb ft
    Fuel Return Pipe Eye Bolt - Injector Side
    16 N·m
    12 lb ft
    Fuel Return Pipe Sleeve Nut
    41 N·m
    30 lb ft
    Fuel Return Sleeve Unit
    41 N·m
    30 lb ft
    Fuel Injection Pump Assembly to Cylinder Block Bolt
    21 N·m
    15 lb ft
    Fuel Injection Pump to Bracket Bolt
    21 N·m
    15 lb ft
    Fuel Injection Pump Drive Gear Nut
    70 N·m
    52 lb ft
    Fuel Line Bracket Nut
    21 N·m
    15 lb ft
    Fuel Temperature Sensor Eye Bolt
    15 N·m
    11 lb ft
    Function Block Nut
    25 N·m
    18 lb ft
    Function Block to Injection Pipe Nut
    41 N·m
    30 lb ft
    Generator Bracket Bolt
    50 N·m
    37 lb ft
    Generator Positive Cable Nut
    9 N·m
    80 lb in
    Glow Plug
    18 N·m
    13 lb ft
    Glow Plug Connector Nut
    2 N·m
    18 lb in
    Glow Plug Power Feed Nut
    15 N·m
    11 lb ft
    Glow Plug Relay Assembly Bolt
    25 N·m
    18 lb ft
    Heater Outlet Pipe/Nose Bolt
    25 N·m
    18 lb ft
    Heater Outlet Pipe/Hose Nut
    9 N·m
    80 lb in
    Heater Pipe Bolt
    21 N·m
    15 lb ft
    Hood Hinge Bolt
    25 N·m
    18 lb ft
    Idle Pulley Bolt/Screw
    37 N·m
    27 lb ft
    Injector Bracket Bolt
    50 N·m
    37 lb ft
    Injector Harness Bracket Bolt
    9 N·m
    80 lb in
    Injector Terminal Nut
    2 N·m
    18 lb in
    Injector Pipe Lock Plate Screws
    4 N·m
    35 lb in
    Intake Air Heater
    50 N·m
    37 lb ft
    Intake Air Heater Terminal Nut
    4 N·m
    35 lb in
    Intake Manifold Bolts/Nuts
    21 N·m
    15 lb ft
    Intake Manifold Tube Bolts/Nuts
    9 N·m
    80 lb in
    Oil Cooler Adapter Bolts
    21 N·m
    15 lb ft
    Oil Cooler Adapter Nuts
    25 N·m
    18 lb ft
    Oil Cooler Assembly Bolts
    25 N·m
    18 lb ft
    Oil Cooler Adapter Stud
    10 N·m
    89 lb in
    Oil Drain Plug
    84 N·m
    62 lb ft
    Oil Fill Tube Bolt
    21 N·m
    15 lb ft
    Oil Filter
    24 N·m
    18 lb ft
    Oil Gallery Plugs
    53 N·m
    39 lb ft
    Oil Level Indicator Tube Bolt
    21 N·m
    15 lb ft
    Oil Level Sensor Bolt
    10 N·m
    89 lb in
    Oil Pan Bolts/Nuts - Lower
    10 N·m
    89 lb in
    Oil Pan Bolt - Upper
    20 N·m
    15 lb ft
    Oil Pan Skid Plate Bolt
    20 N·m
    15 lb ft
    Oil Pressure Sensor Unit
    30 N·m
    22 lb ft
    Oil Pressure Relief Valve
    39 N·m
    29 lb ft
    Oil Pump Bolt
    21 N·m
    15 lb ft
    Oil Pump Driven Gear Nut
    100 N·m
    74 lb ft
    Oil Pump Gear Cover Bolt
    21 N·m
    15 lb ft
    Oil Strainer Bolts/Nuts
    25 N·m
    18 lb ft
    Piston Cooling Nozzle Eye Bolt
    21 N·m
    15 lb ft
    Positive Cable Junction Block Bracket to Power Steering Pump Bolt
    9 N·m
    80 lb in
    Positive Crankcase Ventilation Cover Screws
    4 N·m
    35 lb in
    Positive Crankcase Ventilation Oil Separator Bracket Nut
    25 N·m
    18 lb ft
    50 N·m
    37 lb ft
    50 N·m
    37 lb ft
    46 N·m
    34 lb ft
    Rocker Arm Shaft Bracket Bolt
    41 N·m
    30 lb ft
    Starter Motor Bolt
    78 N·m
    58 lb ft
    Transmission Fill Tube Nut
    18 N·m
    13 lb ft
    Thermostat Housing Bolts/Nuts
    25 N·m
    18 lb ft
    Thermostat Cover Bolt
    21 N·m
    15 lb ft
    Torque Converter Bolt
    60 N·m
    44 lb ft
    Transmission Oil Cooler Clip Nut
    9 N·m
    80 lb in
    Turbocharger Bolt
    108 N·m
    80 lb ft
    Turbocharger Boost Sensor Bolt
    10 N·m
    89 lb in
    Turbocharger Coolant Outlet Pipe Bracket Bolts
    21 N·m
    15 lb ft
    Turbocharger Heat Shield Bolts
    9 N·m
    80 lb in
    Turbocharger Inlet Duct to Turbocharger Bolt
    9 N·m
    80 lb in
    Turbocharger Oil Return Pipe Stud
    10 N·m
    89 lb in
    Turbocharger Oil Supply Hose Eye Bolt
    34 N·m
    25 lb ft
    Turbocharger Oil Return Pipe Bolts/Nuts
    21 N·m
    15 lb ft
    Turbocharger Thermostatic Coolant Valve
    60 N·m
    44 lb ft
    Upper Oil Pan to Flywheel Housing Screws
    20 N·m
    15 lb ft
    Vacuum Pump Nuts - California Emissions
    22 N·m
    16 lb ft
    Valve Adjusting Screw Nut
    22 N·m
    16 lb ft
    Valve Lifter Holdown Bracket Bolt
    11 N·m
    97 lb in
    Valve Rocker Arm Cover Bolt - Lower
    10 N·m
    89 lb in
    Valve Rocker Arm Cover Bolt - Upper
    8 N·m (Two Times)
    71 lb in (Two Times)
    Water Outlet Bolts
    25 N·m
    18 lb ft
    Water Pump Bolt
    21 N·m
    15 lb ft
    Mar 2007
    Pacific Northwest
    There are also three different thicknesses of head gasket plus a right and a left. You will need to check the piston protrusion of the new piston/ bearing assy before assy. Check your e-mail for the procedure. Remember to use new head bolts, rod bolts, crankshaft bearing cap bolts too................. You might try and get yourself a good manual for reference. This isn't your everyday 6.5 diesel!
