Technically, correct. However, not all the fuel pumped actually finds a cylinder. Both engines use the fuel for lubricant and coolant, and return a significant portion to the tank. I don't know which returns more. I don't know which carries more heat, but my truck, even in Winter, will show a hot running fuel temp of 140°+. I've never observed the fuel temp or return rates of a 6.5 system, so I can't compare. I don't know if it even matters, one way or another. I do know several folks who have installed, and are currently running, a 6.5 OEM pump, or similar aftermarket, successfully on LB7's.
