Balance rates are definitely the key to pin point your issue. In the mean time you might run a quart of 2 stroke oil through it to see if you have a stuck injector (sometimes the extra lubrication may unstick the injector). You might get lucky. But if your luck is like mine you will be replacing injectors or the truck.
Jeff
2013 Caprice PPV 6.0L
