Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: Slip from lock up
  1. #21
    I suggest trying a #5 resistor (including a PCM reset). If no joy, then you are probably looking at a failed IP.
  2. #22
    Jun 2002
    NY
    Will do that to day I have a 5 & 4 resistor from previous pmd'
    Ok replaced resistor.
    Now to relearn is that foot to the floor turn on ignition hold down for 45 seconds and still holding peddel down shut off ignition?
    America Love it or Leave!
    1999 Cheverolet K2500 Suburban 4X4 LT
    Hybrid Diesel/Vegetable Oil conversion by me
    In Memory of My Fallen FDNY Brothers
    Never forget Never Forgive
  3. #23
    Jun 2002
    NY
    OK I have tried the #5 resistor and still have the problem.
    No Codes I ran on Hwy with computer connected and there were no codes.
  4. #24
    Did you do a TDC Offset learn after installing the resistor? If not, th ePCM doesn't know it has been changed.
    Have you tried locking OD out by putting the gear selector in "3"?
    Monitor the solenoid closure time while it is acting up and let us know what it reads and if it is steady.
  5. #25
    Jun 2002
    NY
    Talking
    Hi Guys
    Well I think I did is that where you put the pedal to the floor turn on the key and while holding 45seconds the pedal to the floor turn off the key. Take your foot off the pedal and start the truck?
    If that is it then I did it.
    Here is a link to my web site : http://mysite.verizon.net/vze7ye05/
    I have the xls file there if you have excel or a program that opens xls files you can look at it Thanks
    Merry Christmas to all
    We Have a lot of snow on Long Island to night
  6. #26
    I looked at the spread sheet. As far as I can tell, everything looks normal. Exactly what does the file cover? If it covers the "behavior", what timeframe?
  7. #27
    Jun 2002
    NY
    Talking
    Hi
    The spread sheet covers about a half hour of driving from streets to hwy It is from carcode program l asked for all systems check. If all things seem normal then maybe the IP is going the symtoms are worse when the truck is cold but they get a little better as the truck get up to operating temp. The Ip has about 100K on it can I ask for more?
    Thanks for looking
    Merry Christmas
    Truckie117
  8. #28
    If the file covers 1/2 hour then it is not much help. That much data should cover about 20 seconds...
    One last time: Did you try driving with the shifter in "3" instead of OD? Does it do the same thing?
    Do you have EGR? Faulty EGR can cause surging around 45-50 mph.
  9. #29
    Oct 2003
    Maine
    Can you drive and look at what your computer is calling engine temperature? I had a problem where the temperature sensor appeared bad (the one on the crossover)
    I replaced my engine coolant temperature sensor, but that did not fix the problem. Turns out it was the wiring at the sensor. It was also included in the box that the new sensor came with.
    DO what John says. Put the trans in 3 and drive, see if it does the same thing.
  10. #30
    Jun 2002
    NY
    Hi
    Yes John I did drive in just 3rd and still had the same problem. Now that it is below 30 here I seem to have more surging till the truck really warms up. I did change both coolant sensors. One in lower block and the cross over. Just had my wife's car inspected and mechanic at the shop said it sounds like a bad Throttle positioning sensor. Is there a replaceable one on the pump. I was wondering if the injection pump advance solenoid could have anything to do with this and where is it located?
    The truck starts up like a champ glow light goes out turn the key and bang she is running.
    Once warmed up she idles smooth as silk. runs great warmed up untill 45mph.
    I have gm online service manual but that is a lot of information to wade through.
    Hard to work on broken truck and take care sick wife.
    Thanks Guys
  11. #31
    Does it have EGR?
    Do the symptoms in "3" occur at the same engine speed or the same road speed?
    Problems with the throttle and with the advance solenoid will set codes. Also, you can watch the actual vs. desired injection timing and the throttle position with your scan software. The throttle position sensor is on the end of the shaft attached to the accelerator pedal.
    Have you confirmed the fuel pressure to the injection pump? Have you changed the filter and tried straight Diesel fuel? Any chance the veggie oil has deteriorated the fuel lines? The symptoms sound more like a fuel problem than an electronics problem.
    Can you get a 10-20 second snapshot including every data frame from a time when it is surging?
  12. #32
    Jun 2002
    NY
    John
    Does not have EGR which is located on the top of the intake I do not have the plastic cover on the engine I do not run veg and have not for a while. The lines are new and I do a regular fuel filter change. I have a fuel pressure gauge in cab and that is how I knew the lift pump was gone that is now changed. To me it doesent seem like a fuel problem because I can go as fast as i want it is just when I let off the accelerator that the engine seems to not be able to find a happy medium it just seems to drop off. To controll it I just take my foot off accelerator and coast till I reach 55 and then try to touch the pedal to keep a steady speed. I should video this. Also only laptop with xp took a dump and now I cant find xp disk to fix they are at my job so it will be a while.
    Truckie
  13. #33
    Jun 2002
    NY
    Default Pmd
    Hi
    Does anyone know how to check if the pmd id good? I have a new pmd DTECh and my mechanic says that the pmd needs to be changed because he is getting reading on scanner that there is something wrong. I had to bring the truck in because I do not have the time while caring for my wife. Does the resistors ever go bad? I replaced the #9 with a 5 because someone said the #9 might give the problems I am having.
    At the end of my rope thanks
