You could also swap the PROM chip in your 94's ECM to an updated one to work with the new style 5521 IP if your 94 hasn't been upgraded yet. As for the DURAMAX swap, I documented mine here in some detail and theres a few others.
This will give you an idea of how I did mine and what all I went through with my 95 SUBURBAN.
http://www.thedieselpageforums.com/t...ad.php?t=34348
