Originally Posted by
85chevyk30
I will call advanced adapters tom. and see how much they are. I got you another questions since my tcase is eletronic i want to retro fit a push button from my body style truck instead of the 01 push button could it be done.
It might be doable, but I honestly couldn't tell you for certain. I know that the 01+ works in conjunction with the class 2 data bus for info like 4 low and when it's in 4 wheel drive. The encoder motor on the 263 is nothing like that of the earlier styles I have seen either. I went with a floor shifted 261 to simplify all of that as I already had the floor shifter in mine.
