Results 1 to 15 of 15
Thread: Smoke signals
    Jan 2010
    Default Smoke signals
    I've just joined the forum today, but have been scanning the various threads for info on white smoke, injectors, and fuel pressure regulators.
    My 02 Duramax [LB7, I presume] currently has 182K miles, within the new 200K warranty limit, but several months over the 7 year limit for replacing the injectors. In any case, the injectors were replaced under warranty at 102K. [Would be interested to know if anyone has had a second injector replacement under warranty?]
    It was smokin' back at 102 and is smokin' again now. I presumed it might be the injectors and reluctantly drove into the local dealership, Lawley's in Sierra Vista, AZ. They got a P 0089 diagnostic code which indicated a bad fuel pressure regulator which they changed [for a mere $1032 and change] and my Duramax still smokes!
    Back for more tests... the injectors were found to be "within tolerance," i.e., GM would not replace them IF my truck were still under warranty. Nonetheless, fuel was found in the crankcase; part of the $1032 was for an oil change, as well as an air filter replacement. Oddly enough the dealer didn't change the fuel filter, though I found an article on this site that says the fuel filter should be checked/replaced for any DTC related to fuel rail pressure.
    Late last week the dealership -- which seems to be "working with me"-- did a compression check w/o charge. Passenger side bank: 285/280/282/280 Driver side bank: 260/250/270/280. Thus, driver side is low and uneven. I think this is bad news, but not sure just HOW bad.
    Sorry for this long, long post...
    So now what? Any idea where the white smoke might be coming from? The only major repair other than the injector replacement at 102K was a water pump replacement 2,000 miles back. It was leaking from a weep hole, indicating worn seals...? The coolant is holding steady.
    Any advice out there? I don't want to replace the injectors and find it still smokes. Is there no definitive test to determine the reason for the smoking? I've experienced no loss in power, but the smoke screen is embarrassing and not doing the environment any good.
    In any case, what's the "life expectancy" of a diesel engine. Someone suggest to me that it should last to 300K and beyond. Yes? No? Maybe...
    Any and all advice appreciated.
    John Floyd
    02 Silverado 2500HD Duramax
    02 New Horizon 31ft Fifth Wheel
    Jan 2010
    Default No help...?
    Two days, 42 views and no help? Maybe I confused the issue with too many questions. Basically, I'd like to know if anyone else has had white smoke and difficulty diagnosing the problem?
    John Floyd
    OK, I'm not an expert here, but....
    If you are getting fuel in the crank case consistently, I think you need injectors.
    What are the return rates for the injectors?
    Does the cooling system still have pressure after sitting for 6-8 hours?
    Yes, unfortunately there are (too) many LB7 owners here that have had multiple sets of injectors replaced, all within the 200K/7yr period.
    GM has been tightening up their 'goodwill' extensions on injector warranty. You need to push to get this done - sooner than later - siting
    1. the unacceptably short lifespan of the first replacement set;
    2. ...the $1100 already spent on your dealer throwing parts at the problem, to no avail;
    Sure sounds like you have a couple sprays hanging up. Sorry to hear that, but its not that uncommon with the LB7s. The smoke and fuel dilution are classic signs. I would ignore the compression variances, unless you are experiencing low power, rough idle, or unacceptable oil consumption.
    Don't take no for an answer! Ask that your request be elevated to GM's Customer Service. Get your timeline and your receipts in order, and documented thoroughly.
    Remember: Even paying half of the next 8, would be better than receiving nothing. Right now, GM is not contractually obligated to replace them, since your warranty term has clearly expired.
    Jan 2010
    <<I can't smell any diesel on the dipstick, but my nose is not very sensitive.>>
    <<These were quoted to me, but I don't remember. I'm meeting with the dealer today and will ask.>>
    <<I don't think so...but will check. I did perform the squeeze-the-radiator-hose test and it does remain flexible with the engine running. As I remember this tests whether the engine compression is getting into the cooling system via a blown head gasket... ?>>
    Thanks for the advice.
    John Floyd
    Jan 2010
    Good advice, Mark. I was hoping for something like that from GM. A couple of days ago I called GM Customer Service on the advice from the dealer, presuming the dealership would support some sort of relief from GM. GM called the dealer while I was on the line and spoke with one of the "writers" [a service person who is a kind of an apprentice] who told GM that the engine needed to be broken down or replaced! I was livid!
    I'm meeting with the service manager today and am hoping for a three-way deal: new injectors 1/3 paid by me, 1/3 by GM, and 1/3 by the dealer. We'll see...
    Thanks,
    John Floyd
    Good luck...and I mean that sincerely. It sucks to feel over the barrel about a product you like, with a company you support, and get the feeling that they won't / can't reciprocate.
    There are lots of independents doing LB7 injector replacement these days - if you are outside warranty you might consider a good independent diesel repair shop to do the work, if GM refuses.
    Nov 2003
    Sonoran desert
    I feel your pain and really wonder now if it is worth hanging on to my 04 LB7. I was just rejected by GM on my first injector warranty replacement attempt (94K miles). Don't feel that Freeway Chevy in Chandler AZ really backed me up either. It is smoking like crazy but I have no other symptoms. Great fuel milage and power. The long term prospects don't look good if the initial replacement doesn't actaully fix the design flaw. If I could just get the first one done...
    2004 Silverado 2500: HD D/A LB7 4X4, SnugTop XV, Bilsteins, AEM Brute Force HD intake, Banks Monster exhaust, Hypertech
    1981 Airstream Excella 280 Turbo Diesel (Isuzu 6BD1T/Chevy P30) Motorhome
    2010 VW Golf TDI
    My 2002 K2500 (LB7) had its first set done at ~160K miles, and then it started smoking again at idle around ~270K. Neither time did it 'make oil', so I decided to continue to treat the symptom with an old farmer remedy - addin ATF to the fuel.
    I added 1 quart of the cheapest no-name brand ATF I could find, usually every 2nd or 3rd fill-up, or when the smoking was bad, I'd add one quart every tankful until the smoking subsided. Sold that truck with a snowplow on it (...with disclosure of the smoking condition) at ~290K and it was still running well, delivering good mileage, and smoking a little when it idled.
    Don't know why the ATF had the effect that it did, but it did - and the truck never developed a fuel knock or oil dilution problem. I think it just had eroded tips, not a full blown injector housing failure. Obviously it wasn't dumping too much raw fuel or I would have burned it down in 20K miles!
    http://www.thedieselpageforums.com/t...ad.php?t=32737
    Decided the best remedy was no remedy at all - and to never slow down or sit still long enough to let a little smoke bother me!
    Jan 2010
    Met with the dealer's service manager today for an hour and had a good, open and honest discussion. He will contact the district GM service manager and plead my case for some relief. I suggested a three-way split of the cost for replacing all 8 injectors and he seemed okay with that. We'll see.
    John Floyd
    Jan 2010
    Quote Originally Posted by silverback View Post
    Apparently GM is seriously drawing back on their warranty service, especially on the "extended" warranties. In the past they've been very generous and maybe that's part of the reason they got into financial trouble.
    Back in '06 my injectors were failing one at a time. I had one replaced in North Carolina under warranty. Back in AZ another one failed. I tried to get the Chev dealer in Cottonwood, AZ to replace them all. No way. So I went to another dealer, Steve Coury in Camp Verde, who agreed to replace the remaining 7. No way that would happen today. I'm keeping my fingers crossed that GM will agree to a partial deal even though my injectors are only borderline -even though the exhaust is smoking like a green wood fire.
    John Floyd
    Jan 2010
    <<Couple of questioins: What's "make oil"? ... and what's ATF?>>
    Provided GM & the dealer do me a deal this time, I'll remember your remedy for the next time my Duramax develops smoking problems. Apparently, it's inevitable!
    John Floyd
    "Make oil" refers to the increase in oil level as fuel gets dumped into the crankcase. You stated in one of your first posts that fuel was found in the oil.
    ATF is Auto Transmission Fluid. Personally, I would not use ATF. It has too many additives that are not intended to be burned. Marvel Mystery Oil has many of the same properties and burns cleanly.
    YMMV...
    Jan 2010
    Default Conclusion
    I met with the service personnel at the dealership this week. GM would not provide any relief (I had hoped for a 3-way split of the cost of installing new injectors), but the dealership has offered to meet me half-way. They'll install new injectors for 1/2 the usual price, which I was told could range from $4,500 to $5,200. I have accepted the deal and the parts are on order.
    I have a better impression of the dealership. I feel they were very frank and fair with me. I got to meet their chief diesel tech, a young man who owns his own 03 LB7 and turns out is a real enthusiast.
    I'm much less satisfied with GM. I felt since the second set of injectors (installed at 102K) didn't last as long as the originals (80K vs 102K), they should give me some slack --even though I was beyond the 7 year warranty extension.
    So there it is!
    Thanks to all who posted their suggestions!
    John Floyd
  15. #15
    Best of luck to you. Not uncommon to hear these days - GM is really toeing the line on warranty coverage...
