Hello all!
I drive a 97 Chevy 3500. Here's a pic:
I am wondering.... how would you mod this if at all?
Thanks in advance for the suggestions!
Hello all!
Welcome to the board!
Nice looking truck too. What (if anything) has been done to the engine so far?
Contact Me
Content Web Site
Photo Album
TDP Youtube Channel - New!
That is a slick looking beast! Welcome!
Guages, 3in downpipe, open up the exhaust 3-4in pipe. That would be a great start. Start searching through the forums if you want to go any further.
1995 Chevy Z71, 6.5L, 4l80e, 245/75r16 Mastercraft AT's, 3.73's, FSD Cooler, snorkle removed, 233K on the truck 133K on the engine.
Welcome to TDP
4 inch exhaust is a good place to start along with a reflash on the Computer and a turbo master.
Exhaust temp and boost gauges are a must if you reflash and do a turbo master.
Good to have you onboard.
Missy
Stock.....for now
I definitely plan on doing something with the exhaust. For gauges, are you recommending the ones that just slip over the factory needles?
I have some experiences with reflashes and tuning. I used to mess around with Hondas back in the day. What is a turbo master? Doesn't sound like your conventional "turbo kit".
Gauges
A pyrometer and a Boost gauge as in add on gauges either in a pillar pod or some other extra gauge mounting device
Once you reflash the thing and do other mods you then become the guardian of the engine. (Keeping Exhaust temps in check)
Turbo Master
A very basic spring device that replaces the often troublesome vacuum controls on the existing turbo.
You simply tighten the adjustment to achieve the maximum boost desired
12-13 PSI under hard load.
Exhaust temp at a max of 1000F at the outlet of the LH manifold.
Missy
I agree with the mods outlined above and have done them myself: huge difference!
I'm shocked nobody mentioned a remote cooler kit for the PMD.
Maybe you've already learned this from TDP, Spoolin, but the Pump-Mounted Driver (PMD), also called The Fuel Solenoid Driver (FSD) when not mounted on the injection pump, has been the bain of the 6.5 for years.
Mounted on the IP in the hottest part of the engine bay, it heats up excessively and fails. When it fails (and it will) you could be driving along like normal and it's like someone reaches over and turns your key off!
There are numerous accounts all over TDP of wide ranging symptoms, no-starts, etc caused by a failing PMD. The fix is to install a new one on a heat-sink subject to good airflow. You'll need an extension wiring harness as well. There are a few different styles available and a bunch of ways you can mount it. I have a Heath Diesel model (the maker of the Turbo Master mechanical boost control Missy spoke of) mounted in front of my front skid plate. Works well for me.
As I said, I totally agree with the exhaust, Turbo Master, and chip (mine are all Heath Diesel, but you have options, Kennedy and others), but I would argue that the FSD/PMD fix be done 1st as a matter of safety.
By the way, that truck looks wicked!
Cheers
Brett
2005 GMC Sierra SLT Dually Crew, 4x4, stock
71,000 kms
^^ Thanks for the info! I'll be sure to check that out. Can't wait to get started!
The order of the mods is important:
A new radiator altogether is a cheap investment into a happy 6.5L for its second lease on life.
- Exhaust / Gauges
- Boost increase / Fuel increase
- HD Fan clutch (if you intend to tow in the heat)
Would also run a quality engine oil - Mobil Delvac stayed in my 6.5L much better than any other brands. Consumption was half.
what kind of rims are those?
Those are Eagle Alloys, www.aewheel.com
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
