Results 1 to 6 of 6
Thread: Switch to Synthetic Oil - What Mileage?
    Default Switch to Synthetic Oil - What Mileage?
    What's the general consensus as to how many miles a new Duramax engine should have on it before going to a fully synthetic motor oil?
    I always did it at the 6,000 mile mark on Harley V-twins, but I'm thinking I will hit 10,000 on the DMax before I switch.
    Thanks in advance.
    2009 GMC SLT 3500 Xtended Cab 6.6L
    Lubricated By Rotella T-6 and Amsoil EAO52 Filter
    I guess there is no concensus on this one, Dutch. Go with your gut and change at 10K.
    I was going to go with Red Line 15/40 diesel oil (which I've used for years in my 6.2)... but after doing some more research.. I'm opting for Rotella T-6... primarily bacause of the low ash additives.
    Figure the T-6 with an Amsoil 25K filter should cut my oil changes to a semi-annual ritual.
    Run Amsoil 15-40 Diesel 100 percent Synthetic the best. Become a preferred customer like I did. You get it for wholesale sent to your door in two days. I also run the Amsoil EaO synthetic oil filter. Amsoil is the best you get the best protection and mileage!
    Quote Originally Posted by WyoDutch View Post
    Thanks in advance.
    There was a discussion a few years ago at GM concerning whether to pre-fill all of the Duramax 6600 engines with Mobil Delvac 1 5W-40 synthetic from the factory. They do this with the Corvette engines.
    There are lubrication engineers and others I trust who say you can pour in synthetic from the very beginning, and that no break-in time is needed. Personally, I'd not do it for a while cuz I like to change the oil within 1000 miles of new to remove any manufacturing particles and assembly lube. From that point on, use whatever meets the powertrain warranty.
    Sep 2006
    Brooker, FL
    Synthetic oil has no effect on breakin. Piston aircraft engines do need a breakin period, exprcially if a cylinder has been replaced, or if it has chromed cylinders.
