I have way too many parts left over from my projects and need to move them - for the money and the space they take up. I'll make package deals! I have lots of other small parts as well. You can PM me or for fastest response, send me an email if you need something.
Like new standard oil pump $25.00
1 set of 8 6.5 pistons & rings, standard bore, test run only, $250
Email for more details & pictures - pistons & rings only, rods not incl.
6.5 block - #8 cylinder has a crack at the top. I just had the oil pan off and did not see any web cracks, but I did not remove the main caps. Asking $100 as is.
Pair of used 6.5 turbo heads, diamond precups, $250 for the pair
Crankshaft $100
Also would sell the rods, cam, most all internals from 1997 6.5 TD except timing chain & gears
6.5 DB2 injection lines, good condition, $75 for the set
As new #1 injection line for DB2 without the timing adapter, $25
DS4 injection lines $25.00 set of 8
I have 2 aluminum front timing chain covers, $35 each
Steel back cover for water pump, $20
Crank dampers for DS4 engines, part 10154688. 1 very good $60, one good $40
NA Hummer Headers - One set of 6.5 Diesel Headers, complete with crossover pipe. You need to supply the bolts. Crossover pipes are 2¼" and the collector is 2½". No idea if they will fit a truck, but I can tell you they look the business! A couple of small dents, but very good shape. $75 for all
24 Volt glow plugs - these look like new. One set of 8, but two were damaged, one is bent and unusable, one has a bent electrical prong, may be OK, not sure. All ohm good. $35
24 Volt cold start sensor. Wire has slight damage, but ohms good and looks like new. $10
Crossover from Hummer? Has 24 volt glow plug controller, temp sensor and thermostat & cover part # 12554091 cast on. $35.00
NA intake - like new, Has 23500011 cast on manifold. $40.00
One set of 8 Genuine Bosch 311 "Marine" injectors, used for only 10-15,000 miles. I sent these to a well known injection shop to be tested and the pop pressure set. I was told they were "burned" and should be replaced. They came out of a well running engine. $50 for all 8, good for beater or cores.
2 rebuilt 6.5 fuel injectors $40.00
1997-1999 Fan Clutch, Genuine GM, part # 15022302 fits HO water pump with bolt on fan clutch and later 4 bolt 6.5 and Duramax fans, excellent cond. $50.00
Flex fan for serpentine belt setup, came off used 6.5, includes spacer & mounting hardware, totally eliminates the fan clutch, fits 4 bolt water pump. $20.00
Factory Oil Cooler and lines from 1995 6.5 Diesel, lines were replaced with new lines from dealer in 2004, no leaks, complete set up, includes 4 new O rings & new spring clips. I can include block adapters if required, I have both sizes of block adapters so your choice. $50.00
Throttle Position Sensor for DB2 pump $50 or with wiring connector $85.00
Radiator from 1995 Suburban 6.5, has trans cooler in RH tank, aluminum with plastic end caps. Never leaked, some bent fins, I replaced with new as precaution. $50.00
Hummer hydraulic fan clutch, as new $50 Fan & lower 4 V belt pulleys, $25 each
Water pump, test run only $25
Turbo Kit Includes:
GM3 Turbo with mechanical wastegate. Spins free, good condition, includes 90 degree elbow to exhaust and clamp for down pipe.
1993 Turbo Diesel Exhaust manifolds, has one or two broken crossover studs, otherwise good cond. Can include crossover, its a little beat but usable. No down pipe.
1993 Turbo Intake manifold, upper & lower, NON EGR,
I do not have the rubber hose from turbo to intake manifold
Exhaust heat shields
One heat shield for glow plugs under turbo.
Turbo brace to intake manifold mount bolt
Turbo brace to upper intake
Turbo Oil return tube, hose and plate for fuel pump.
CDR valve
$300 plus shipping takes it all or will sell separate, email for details
Used Autolite glow plugs. Set of 8, all ohm good, $30
Oil fill tube & cap $20
Crank timing chain cog for electronic engines with reluctor cast on, like new, $15.00
Valve covers Turbo Type, one CDR, one regular $50 pair, NA type 2 X regular $35.00 pair
All prices plus shipping or pick up free in Jacksonville, Florida
If you nee a small parts and don't see it listed, please email. I have lots more parts, but have not had time to catalog everything. Thanks!
