ill take
Turbo brace to intake manifold mount bolt $5.00
Turbo brace to upper intake $5.00
shipping is 22039
also what shape is the cdr in?
How do you want to be paid?
Andrew
ill take
shipping is 22039
Andrew
85 m1008 -6.2/465/205
Bobbie Martin1995 Chevrolet Suburban 1500 6.5 TD 2WD- DB2 mechanical fuel injection
GEP Optimizer 6.53 Detroit Diesel Power
6.53L, GEP Block & Heads, .020 over, ARP studs, DB2 Inj. pump, GM8 Turbo w/TurboMaster
K47 Airbox with K&N filter, 3" mandrel bent exhaust, 2¼" Crossover, Mann ProVent
HO Water Pump, Hayden "Truck Fan" Clutch, 21" 9 blade Duramax Fan
No PMD, APP, CDR, optical sensor or vacuum pump!
Author of The DB2 Conversion Guide
Click Here to Email Me
Hummer water crossover & flex fan are sold
Time to move this stuff! New lower prices.
Like new standard oil pump $20.00
1 set of 8 6.5 pistons & rings, standard bore, test run only, $125.00
Email for more details & pictures - pistons & rings only, rods not incl.
6.5 DB2 injection lines, good condition, $60 for the set
As new #1 injection line for DB2 without the timing adapter, $25
DS4 injection lines $25.00 set of 8
I have 2 aluminum front timing chain covers, $25 each
Steel back cover for water pump, $20
Crank dampers for DS4 engines, part 10154688. 1 very good $50, one good $25
24 Volt glow plugs - these look like new. One set of 8, but two were damaged, one is bent and unusable, one has a bent electrical prong, may be OK, not sure. All ohm good. $25
NA intake - like new, Has 23500011 cast on manifold. $40.00
2 rebuilt 6.5 fuel injectors $40.00
1997-1999 Fan Clutch, Genuine GM, part # 15022302 fits HO water pump with bolt on fan clutch and later 4 bolt 6.5 and Duramax fans, excellent cond. $40.00
Factory Oil Cooler and lines from 1995 6.5 Diesel, lines were replaced with new lines from dealer in 2004, no leaks, complete set up, includes 4 new O rings & new spring clips. I can include block adapters if required, I have both sizes of block adapters so your choice. $45.00
Throttle Position Sensor for DB2 pump $50
Hummer hydraulic fan clutch, 4 V belt pulleys for fan & lower crank and the Water pump, test run only $75 takes it all
1993 Turbo Diesel Exhaust manifolds, has one or two broken crossover studs, otherwise good cond. Can include crossover, its a little beat but usable. No down pipe. $50
1993 Turbo Intake manifold, upper & lower, NON EGR $50
Used Autolite glow plugs. Set of 8, all ohm good, $25
Oil fill tube $10.00
Crank timing chain cog for electronic engines with reluctor cast on, like new, $15.00
Valve covers for CDR valve $25 each
CDR valve $20
Exhaust heat shields $10 each
Good used 6.5 starter $45.00
Pistons are sold!
1999 F-250 PowerStroke Crew Cab Short Box Lariat 4X4
Fumoto, Turbo-Master, MBRP 4", Billet Triple Disc TC, HD TransGo Tugger, AIS, Triple Pod, Autometer Phantoms, SPDiesel Overboost Eliminator, SCT Tuned By Tadd @ Elite Diesel Performance 75/100/125 and DP-Tuner 80 Econo PCM, Sirius Radio...
2006 Jeep Liberty CRD Sport 4X4
Stock for now...
My Gallery
The following parts are still available:
Aluminum front timing chain cover, $25
Crank dampers for electronic 6.5 Diesel engines, part 10154688. 1 very good $40, one good $20
Hummer hydraulic fan clutch, fan & lower 4 V belt pulleys and water pump & backplate , test run only $75 for all, parts are as new
1993 Turbo Diesel Exhaust manifolds, has one or two broken crossover studs, otherwise good cond. Can include crossover, its a little beat but usable. $50.00
1993 Turbo Intake manifold, upper & lower, NON EGR, $50.00
Crank timing chain gear for electronic engines with reluctor cast on, like new, $15.00
Valve covers with or without CDR fitting $25 each
Flex plate for 6.5 with 4L80E $30.00
Cover for trans/flex plate $20.00
Turbo brace to intake manifold mount bolt $5.00 Turbo brace to upper intake $5.00
