Results 1 to 7 of 7
Thread: Short Bed, can I tow a fifth wheel?
    Jul 2008
    Lansing ,MI
    Default Short Bed, can I tow a fifth wheel?
    Hey all, I have a 6.5 ft bed and there are already rails in the truck (were there when i bought it). Can I tow a fifth wheel if I get a sliding hitch? And do I have to stop all the time if I have to make a tight turn and slide out the hitch, or can I just tow with it to its rear most position?
    Thank you
    1991 Chevrolet Silverado 3500, 6.2L. 125,000 miles -Sold
    2007 Chevrolet Silverado LBZ - R.I.P
    2001 Chevrolet Silverado LB7-- Sold
    2011 GMC Sierra, LML- 39,000 miles. All stock
    The difference between long and short beds isn't that much. Only 9-10" in hitch position in relation to the cab. No, you won't have to stop all the time. You will have to slide if you need to maneuver and jack-knife. The turning clearance is not bad, at all. I've been doing it with a short bed for years, and don't miss the long bed. My current 5'er has a hitch pin behind the front of the trailer, making it closer, and still isn't a problem. I even have room for a small motorcycle in the bed in front of the hitch, but I do have to watch that one (still no problem maneuvering on surface streets). I slide it back for getting it into and parked at my house and when off the highway (desert/campgrounds), but hardly ever any other time.
    Jul 2008
    Lansing ,MI
    Thanks for the input Dmax Maverick, I think i'll still look into a sliding hitch just in case, but im more at ease knowing what you said.
    Does it matter where the rails are in the truck bed? Mine are right about inbetween the wheel wells. Would it hurt to move the rails more towards the tailgate to help clearance issues?
    The rails need to be deliberately located. You can't just put them where they are convenient. They should be centered about 1" in front of the axle on a short bed extended cab 2500HD. The rail center determines the hitch weight distribution. If you get a slider (highly recommended), it'll be a non-issue. Most all maneuvering can be done with it forward in travel mode. If you need more turning ability, slide it back. That simple. You don't/can't leave it slid back, as that places the hitch center well behind the axle, and would likely not be legal with a moderate pin weight (axle and tire overloading). The Reese (and clones) have a 9-12" slide travel, so slid back puts the pin center +8" behind the axle.
    With my 5'er on and motorcycle in the bed (placed across, at the front, and as high as the cab), I can still get around town and make right turns. It gets really close maneuvering parking lots and such, but no problem during normal driving. The pin placement on your coach can effect the amount of turning ability you have, too. Where is your pin, in relation to the front corners of the 5'er?
    Or....You could fork out the bucks and get an auto-slider. It automatically (cam system) slides the hitch rearward more as the turn increases, and returns to forward as you straighten out. Very nice, but very spendy ($3K-ish for new).
    Jan 2009
    Have a Reese Slider but haven't needed to use it yet. My 5ver has a front cap enhanced for use with short bed trucks. As DM said never tow with slider in rear position. Some have also tied the pin extender but seems, from what I have read, this puts a lot of extra strain on the 5ver front framing and pin box connections.
    2008 2500HD Ext. 4X4
    265/75R16
    Reese Signature 18k slider
    Montana 38.4 ft 5th wheel
    Mar 2002
    L.A.
    Default New Trailer
    If you don't have the trailer yet and aren't looking for a toy hauler, check out Titanium Trailers. They have a trick front end that doesn't require a sliding hitch. Also, the front end of the trailer hangs over the cab so you don't have so much behind you. I have a rack on the back of mine for my dirtbike.
