Results 1 to 6 of 6
Thread: Help I need to get to the Finish Line
    Jun 2002
    NY
    Red face Help I need to get to the Finish Line
    HI
    I am almost done connecting everything up after replacing the IP.
    I am left with one plug I dont know where it goes I will post a pic.
    All the connectors seem to only mate with there mates. Is there any way to miss attach a connector in the harness or do they only have one mate.
    Thanks
    Mike
    America Love it or Leave!
    1999 Cheverolet K2500 Suburban 4X4 LT
    Hybrid Diesel/Vegetable Oil conversion by me
    In Memory of My Fallen FDNY Brothers
    Never forget Never Forgive
    Jun 2002
    NY
    Default Pictures
    Here are the pictures of the plug and harness
    This is the drivers side and the plug comes out of the same place as the engine temp sensor.
    I just cant remember where the red plug goes. Hate to fire this up and fry everything.
    Thanks
    May 2002
    Stratford, Ct. // Stoddard NH
    it would be helpful if you had the general location of this plug...but pretty much you can only hook things up one way...so go for it..
    It might go to the top of the inlet manifold...
    Could also go to the crank sensor....or a temp sensor...one is on the water inlet.....
    Look around it will be obvious..
    enjoy
    95 Suburban 1500 Bone Stock Orig.
    purchased at 103K from first owner
    new alternator/autozone gold @104K
    re-trannyed with shift kit @107.5K
    new Bilsteins all around @ 127K
    Kennedy exhaust @128k ..zoom!
    new lift pump w/OPS bypass @ 130K
    Kennedy FSD cooler @ 135K
    New IP/Injectors/G-plugs @ 137k
    Another autozone alternator and Optima Reds @ 150K
    Another pump and injectors @157K
    New chain and gears @157K
    HO pump single therm setup @157K (will see what happens)
    Head gasket or worse to be determined...164k
    NEW AM General 6.5 installed and running well! @ 164K!!!!!
    Sep 2006
    Did you pull the front cover off? It sure looks like the crank position sensor. I am in the middle of installing phazers and 97 cooling mods right now. When I get back to it tommorrow, I will look and let you know if you are still stuck....
    1994 6.5 HO vin "F" X-cab, long box 4x4
    Phazer set installed, 97+ cooling mods with 9-blade fan.Turbomaster, gauges, OPS mods with selenoid and lift pump indicator light 4" turbo back open exhaust, remote dual oil by-pass, Amsoil 15w-40, remote PMD #9, battery mods, 98+ airbox, 3.42s w/ NV 4500 converted to South Bend SM system with damper installed, 147K.
    Jun 2002
    NY
    Talking
    Found It was the connector for the power steering pump didnt know there was a connection there although i did disconnect it. We are ready to finish up now connect all hoses and fill with water first. Any special procedure to starting up with a new IP?
    Thanks
    Mike
    Yank the glow plugs out to releave the compression
    Make sure you have air free fuel to the inlet of the IP
    All other connections tight and ready to go.
    Spin the engine until fuel mist comes out the glow plug ports.
    Install glow plugs
    Start as normal
    Engine may miss and sputter a little at first but will clear out quickly.
    Removing the glow plugs greatly speeds the process and really takes the stress off the starter and batteries.
    This is a procedure that I have followed for years.
    The engine also will spin at a much greater RPM, thus speeding the process.
    The injectors bleed air out fast too as the IP is not having to fight the 400 PSI compression pressures.
    Have fun and good luck.
    Robyn
