zerk fitting locations Duramax
Hi,
All my searches for Zerk locations turned up links that have long expired. If someone would be so kind to post or email some photos I will place them on a server that will be around for a long time.
My specific truck is a 2006 C3500 4wd crew cab dually. I can find 10 of the proposed fittings easily ie: 6 on the tie rod assembly (4 on ends of tie rods, 1 on idler arm and 1 on steering arm)
4 on ball joints, upper and lower each side. There is supposed to be 1 more from what I gather but I can't locate it.
Thanks, Splitrimz
1994 C3500 6.5TD CREWCAB DUALLY, Heath Turbomaster, cone style cold air intake, PMD cooler mounted under grill, Banks boost and exhaust temp gauges, OPS bypass, Air Lift rear bags.
2006 LBZ LTD, 4WD, CREW CAB DUALLY.
