Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: My Intercooler project
  1. #21
    Nov 2008
    Tromsoe Norway
    Quote Originally Posted by JTodd View Post
    I am not sure if it will work, but I really like the look of it. Well done.
    thanks, i think it will work
    New sub. 1996 6.5 ls 1500.
    1994 Suburban K2500HD. 6,5 TD 251 000km. sold
    3,5 inch exhaust, no cat.
    Marine injectors. Removed snorkle
    opened intake plenum. 3 gauge pillar. EGT.Turbo.Tranny temp. Fsd Cooler, resistor nr 9.
    Top mounted Air to Air intercooler. Kennedy Turbo master
    intercooler is installed.
    look in: http://www.thedieselpageforums.com/t...ad.php?t=37313
  2. #22
    Very nice looking job.
    Lets see the underhood Plumbing parts
    Robyn
  3. #23
    Nov 2008
    Tromsoe Norway
    Robyn
    will post as soon as i am done, during the weekend..
  4. #24
    Nov 2008
    Tromsoe Norway
    Updated pictures from my project..
    nr10: protection from debries and water.
    nr11: protection installed
    nr12,13,14,15: pics of the brackets for the cooler
  5. #25
    Nov 2008
    Tromsoe Norway
    Som more.
    nr16: The cooler on the mounts
    nr17: intake after modification
    nr18: The "plumbing"
    nr19: new decals
  6. #26
    Nov 2008
    Tromsoe Norway
    Starting on installing the fan.
    it will be mounted under the cooler.
  7. #27
    Nov 2008
    Tromsoe Norway
    Fan installed with a temp.controller that sense the intake air temperature.
    i can adjust it from 0-100 degrees.celcius.
    Works like a dream
    After a normal drive until engine has normal temperature, i can feel a big difference in surface temp from the cooler intake side to the outlet side.
    havent measured it but it feels like 20-30 degrees difference.
    and that will match the measuring i have done too. i have about 20 degrees lower intake temp after cooler install.
  8. #28
    Any Updates?
  9. #29
    Nov 2008
    Tromsoe Norway
    Soon i will getmy car pc installed again, and then i can measur some more.
    i had to order a new touch screen...
