Results 1 to 5 of 5
Thread: 1982-1999 K-Blazer/2-door Tahoe, and Suburban curb weights
    Default 1982-1999 K-Blazer/2-door Tahoe, and Suburban curb weights
    Does anyone know what the curb weights for the 1982-1991 K-Blazer and Suburban K1500 and K2500; not only with the 6.2 liter diesel, but also the 454 Big Block V8, 350 Small Block V8, and 305 Small Block V8?
    And the 1992-1999 K-Blazer/2-door Yukon/2-door Tahoe, and Suburban K1500 and K2500 not only with the 6.5 liter NA and Turbo diesels, but also the 454 Big Block V8, and 350 Small Block V8?
    This information is neccessary for maybe towing the vehicle with all four wheels down behind a diesel pusher motorhome with a 10,000 lb. rated hitch, and towing capacity.
    Sep 2002
    Fort Wayne, IN
    Truck451,
    I can only tell you how much my Suburban weighs, since I got it weighed on a scale last Spring.
    I have a 1996 K2500 Suburban SLE (has an extra leaf in the rear spring pack) - 7000 lbs.
    Hopefully others can give you the other weights you need.
    Bill
    Bill
    1996 K2500 Suburban - Purchased in Sept. 2002 - 297K miles
    Only mods - K&N filter, Greg's Oil Cooler Lines, Home-made FSD heatsink, Kennedy quick heat glow plugs, LED interior lights, Kenwood stereo, 2001 GMC aluminum rims. AutoMeter Guages (boost, EGT, TransTemp)
    2007 GMC Acadia SLE - wifes car.
    1987 Buick GN totally stock - 48K miles
    Oct 2006
    Lexington, KY
    http://coloradok5.com/specs.shtml
    That's the specs for the K5's. I think the listed weight is the factory listed curb weight because I know the GVWR is higher on mine.
    Edmunds.com should have the specs for the 92+ trucks.
    -89 K5 Blazer. "The Blazer." 6.2L diesel, 33's, Rhino Lining, and stock(ish). Tow rig, play toy, and general fun.
    IIRC they are about # 5200
    I weighed my 89 some months back but cnat remember exactly.
    Jan 2002
    West Orange, NJ, USA
    Post My old 94 6.5TD Blazer
    weighed about 5900 lbs, iirc, with me, my 70# dog, and a pretty full fuel tank. Just for my own info, checked it on a scale at a 'yard that did work on it for me. HTH.
    Blazer & dog are gone, miss them both.
    Dave
