Thread: Hid Back Up Lights For 88-2011
    Burning Oil's Avatar
    Jul 2006
    Houston TX
    Default Hid Back Up Lights For 88-2011
    HID BACK UP LIGHTS FOR 88 & UP Chevy GMC
    I am offering a kit to convert your dim back up lights to extreamly bright HID back up lights. A normal kit is $199, but the 88-98 body style is $245 because of the printed circuit board style lights we have. The boards cost me an additional $30 a set then I have labor to modify them.
    I will also sell just the alluminium adapters for $30 a pair and you can mod your own.
    Now offering a kit so you can install HID headlights as your back up light. Will work on most any vehicle. I have installed these on several trucks and they are stunning in the difference (like day and night). They make a great work light also, my kit will let you turn on the HIDs anytime you want with a manual switch and/or while in reverse. I use mine almost daily. Women also love them too because they make seeing what's behind you easier.
    I posted a couple years ago about a Ford Super Duty I converted and some pepole had concerns about using HIDs as back up lights.
    They were:
    1. Q) Will they come up to full brightness because you are not in reverse long enough?
    A) Yes they will if you are backing up for more than 2 seconds. They come up to full brightness in the same time as headlights take.
    2. Q) Do they get to hot for the housing?
    A) No, not in my experience. I have had mine on for 30 minutes at a time with no problems. Had a customer (yesterday) leave his on and forgot about them. More than 2 hours later he went out to a dead battery, but at least we know they did not get hot.
    I have been told many times that HIDs have a lower temp than halogens. I never took a reading so can't say for sure.
    I will be selling complete kits for $199+shipping
    OR I will sell just the adapter that attaches to the lens. The adapter allows the HID bulb a means to attach. The adapters are machined from alluminium and are $30+shipping for two. That way you can use the HID kit of your choice. (880 bulbs)
    My kit includes:
    HID light kit
    Alluminium lens to HID bulb adapter
    Relay harness
    10 ga supply wire
    trigger wire w/manual switch
    wire loom
    2 fuse holders
    Misc butt connectors, zip ties.
    Until I find time to put these on the web site please PM/email me if you would like to buy a set/kit
    Pictures to follow next.
    www.pmdcable.com
    Jul 2006
    Houston TX
    OK, Im having problems loading pictures. Will try again later.
    www.pmdcable.com
    Jul 2006
    Houston TX
    OK I have tried at least 10 times to upload photos but keep getting this message " Internet Explorer cannot display the webpage" Can Anyone help me figue this one out. I get as far as loading my pictures in the photo album but when I click submit it gives another page with the message above.
    Leroy
    www.pmdcable.com
    Send me an email or PM with your system info (computer brand/age, operating system version/service pack), recent updates, etc. This comes up from time to time, and it's usually a needed update, patch, or a missing plugin. You could try clearing your cookies and internet history (cache).
    Jul 2006
    Houston TX
    Finnaly got my new web site up. Here is a link the the HID back up lights.
    http://www.pmdcable.com/index.php?ma...=index&cPath=5
    www.pmdcable.com
