I've become somewhat of a reluctant "expert" in bleeding Hydroboost, as I've had the system apart several times in the past year: Replaced 3 pumps (2 Saginaw/Nexteer defective with broken shafts), the HB unit itself, and the HB-operated shaft brake. With the engine in the rear, my lines are about 25' from the pump to the HB, so bleeding is no fun.
I agree with dMax except for one part of the procedure: Don't wait for the pump to complain; if it gets that far, air can be reintroduced into the system.
Use a clear or translucent container and a clear hose. Do the procedure dMax recommends, but stop the engine after a couple of cycles. Top off the reservoir, wait 10 minutes, and repeat until no more bubbles can be seen. Waiting is an important part, so the entrained air can migrate to HB unit where the return line can purge it.
The system does self-bleed, but it's best to start as air-free as possible; because the HB is the system high point, using dMax's technique works very well.
