Results 1 to 5 of 5
Thread: overdrive towing
    Jan 2005
    La Mirada, Cal
    Question overdrive towing
    hello --
    I've just moved up from a turbo 400 to a 4L80E transmission. Can a 3200 pound trailer be towed using overdrive on flat highway or should I keep the transmission in third gear? I'm very familiar with turbo 400 strengths while towing, but I'm at a loss with this overdrive transmission.
    thanks
    04 GMC Sierra, 4x4
    94 suburban, 4x4
    84 suburban, 6.2 with Banks. Turbo 400 w/4.10's. Ex-Fire truck.
    83 Volvo 760 turbo diesel. Yea it's ugly, but it gets 40 mpg on the highway...
    Overdrive is fine. It's "gear hunting" that will kill an auto. If it will hold the hear without shifting in/out often, it's no problem. 3,200# is a lightweight, in any case.
    Jan 2005
    La Mirada, Cal
    Hi Dmax..
    So if it starts to search for gears pull it into 3rd for that section of road. Can I drive with the cruise control on as long as its not hunting for gears..I usually pull at 60-62 mph max.....thanks again.
    04 GMC Sierra, 4x4
    94 suburban, 4x4
    Cruise is fine. Do what you have to do to prevent gear hunting. Speed up, slow down, or downshift. Whatever it takes. Often, getting the engine RPM's right will keep the power up with less pedal (or cruise input), which reduces gear hunting. 2-3 MPH up or down can make a big difference.
    Sep 2006
    Brooker, FL
    I agree. My M/H clocks in at around 16K, with much more frontal area than you have, I run in OD on most flat Interstates.
