Results 1 to 13 of 13
Thread: New here from minnesota
    Feb 2011
    Annandale Minnesota
    Default New here from minnesota
    Just thought I should say hello. I'm new here but not new to diesels. I currently own 11 cheys with 6.5s or 6.2s. I can't seem to get my sig to stick but will get that figured out[entered it twice now]. I have tons of pics and will get to posting them hopefully some time soon. I have one in my avitar now. I enjoy sharing my experience as well as learning from others.
    Now back to reading, Barry
    PS got a couple pics to load. I need to resize the rest. Sig also loaded
    98 K2500HD 6.5td 4l80e 4.10 245-16
    97 K3500 C&C 6.5td 4l80e 4.10 225-16
    97 K2500HD 6.5td 4l80e 3.70 33-12.5-16.5
    95 k2500HD ext. cab 6.5td 4l80e 4.10 265-16
    95 K2500LD 6.5td 4l80e 3.70 245-16
    95 C2500 ext cab 6.2td NV4500 3.70 245-16
    94 K3500 srw 6.5td 4l80e 4.10 245-16
    94 K2500HD 6.5td 4l80e 4.10 265-16
    93 K2500HD 6.5td 4l80e 4.10 245-16 farm truck
    92 K2500HD 6.5td 4l80e 3.40 265-16
    87 Monte Carlo SS 305 200r4
    81 Olds Cutlass Supreme 3.8 buick t200
    GMTD scantech tech1 w/mass storage
    Holy hanna - thats quite a fleet! I am from Elk River, MN and was just through your town yesterday...
    Welcome aboard, there is a wealth of information/experience here for you. I am certain you'll be contributing yours, as well!
    Feb 2011
    Annandale Minnesota
    I have no willpower. I can't pass up a good deal. I think my hobby has turned into a addiction
    Yesssss, indeed, quite the fleet
    Welcome to TDP
    Addiction, well they say that once you get to sniffing that diesel smoke its over, your hooked
    Missy
    Wow! I don't think I've ever seen anyone with such a large collection of 6.5L's. Are these all personal use trucks, or are they business use?
    Welcome!
    Feb 2011
    Annandale Minnesota
    Welcome!
    Personal use only. 3 of them are blown up.1 needs a tranny and another needs a IP. I bought them that way for cheap.I have all the parts to fix them and then some. Here's some of the parts.
    Thumbs up
    Nice fleet, and welcome aboard!
    I've been called (and conceded), a pack rat. Now, I'll have to deny it. "Wow!" is spot on.
    Quote Originally Posted by bk95td View Post
    That's quite a collection! How many complete engines do you have?
    I'd say you're on the edge of being a bit crazy....and I LIKE IT!!
    Wow! Welcome to the board.
    Which one is your favorite?
    Feb 2011
    Annandale Minnesota
    The 92 is my favorite so far. I haven't really done anything to the engine yet other than glow plugs[used ac g60s but should have used bosch] and new hearthrob 4" exhaust with a 2 1/4 mandrel bent crossover. Even with the 3.40 gears it is a workhorse. It pulls 10,000 lbs at 70mph pretty easily. I did put a flexsteel seat in it that is comfy. Kind of a hot rod running empty.
    I have over 20 complete engines. !2 of them have serious problems so they are parts engines. I've junked 6 trucks for parts.
    I got slowed way down last week by a serious back reinjury. I can only stand to play with my trucks for a hour or so a day. I start phy. therepy on monday. I can only hope it will help.
    May 2009
    NH & Eastern NY
    Wow, what a collection! Nice trucks and shop!
    Welcome and good luck with physical therapy!
    NutNbutGMC Guest
    You need counseling, soon.
    Sep 2006
    Brooker, FL
    Naw, not an addiction. He can stop anytime he wants to
