Results 1 to 14 of 14
Thread: Cylinder 7 glow plug failure code
    Aug 2008
    Illinois
    Default Cylinder 7 glow plug failure code
    My 2008 LMM lit the service engine light last evening and when I read the codes it indicates the glow plug for cylinder 7 has failed. I reset the code and it has not returned for several starts now. Does this make any sense. I have not read the resistance of the number 7 glow plug yet- plans to do so later today. Engine only has 78,000 miles on it. The Weather has been in the high 90's the past few days and I have been doing a lot of high speed driving and a fair amount of idling to stay cool, wonder if this has had any affect on the glow plugs or associated electronics
    Sounds normal. Glow plugs fail. Rarely is there a specific reason, short of excessive glow times. They just quit. It's a fact. Your highway driving and idle periods are not likely a factor, or we'd see a lot more failures. Your one plug may or may not be bad, so you should verify by testing. The PCM monitors the GP/heater system under specific conditions. On earlier models, if the sensed ambient temp and/or coolant temp is above 63°F, it isn't monitored. I don't know what the monitoring temp is on the later models. If your temps remain above this, you may not get a code, even with a failed plug.
    Plugs fail for a variety of reasons. It is important to pull it if it's failed, to verify it isn't physically damaged, which could lead to pieces of it falling into the cylinder. If it appears intact, leaving it in will cause no damage, and only be an inconvenience when the SES indicator becomes annoying.
    Aug 2008
    Illinois
    Default Glow plug
    Thanks for the info, had a second code show up after a cold start this afternoon so I disconnected the glowplug and had a resistance of 400 ohms so I replaced it and all is well. Do have a question, where is the sealing surface on the glowplug. I do not see a tapered surface only a flat surface where the heating element of the plug leaves the housing. Is that where it seals?
    It seals on the shoulder where the element exits the body. Unlike spark plugs, this keeps the threads out of the combustion chamber.
    At 400 ohms, the plug should be good. They usually fail open. Put 12V on it and see if it glows. If it does, the problem may have been the connector.
    Aug 2008
    Illinois
    Default Glow Plugs
    I will give that a try, the connections were fairly corroded so I removed all of them from bank one and cleaned and retorqued them
    Suggestion: Dielectric grease
    That and frequent "bathing" to remove road salt.
    Aug 2008
    Illinois
    Default Glowplugs on a 70 degree morning
    Never noticed the glow plug lamp on for 2 seconds or so in previous years when I turned the key to the start position and the morning temp was 65-70 degrees F
    Anyone know if this is normal
    Ed
    Jan 2005
    St. Louis, Missouri (pronounced misery)
    I RARELY see my light anyway unless it is below 40F degrees or so. Even when it is cold like 25f it only comes on for a second.
    I am getting a code too, and would like to piggy back on your post. I DON'T want to hijack it!! I am getting a code on number 4. Is it ok to change just the one, or should I change all?
    Scott
    Scott
    St. Louis, MO
    Glow plugs can be changed one at a time, as needed. There's no need to replace good plugs, as you/we have no way of knowing how long they will last. Some old plugs last forever, while a new plug might last a week. They work, or they don't. Having a spare is handy, but not at all required, like for older machines (6.5/6.2/6.9/7.3, they won't start cold without them). Your truck will start, however sloppy, down to some amazingly cold temps with no plugs at all. I cold-soaked my 2001 for 8 hours at -10° once. I unplugged the plug harness, just to see if it would. Normal cranking time and she fired, ran rough and smoky for about 20 seconds, then normal. That was with all 8 disabled. If only 2 or 3 were out, I probably wouldn't notice, except for the SES lamp.
    Jan 2005
    Thanks for your reply. I'll only replace number four. But to be certain, number four is on the passenger side rear yes?
    Scott
    St. Louis, MO
    Quote Originally Posted by Stlheadake View Post
    Nope. Maybe on a Ford. 1, 3, 5, 7 on the passenger side. 2, 4, 6, 8 on the driver's side. #4 is the second hole from the front, on the driver side. All GM engines are simple. The cylinders are numbered according to their position on the crank, #1 at the front. Most Fords are numbered by bank, and Chryslers depend on the year, weather, wind, and current CEO's secretary's brassiere size.
    Jan 2005
    I'm really happy I asked. In my tiny little brain, I had it all backwards. Thanks for your help! I hope it comes out easy enough! I only have 65k on the truck, and things aren't real rusty....I probably just cursed myself!
    Scott
    St. Louis, MO
    They don't usually fuss too much coming out. Go slow with the turns. If it stalls after a few turns, go back and forth with it a few times, stop at the loosest point, and soak the threads with WD40. Wait 1/2 hour or so, then rock it back and forth until it's loose. Clean the hole and use dielectric grease or silver anti-seize (nickel/silver) on the threads. This will prevent future seizing.
    Hi guys (and gals, if any)
    New to forum, reading up and finding some common problems. #7 is lighting up my SES (I'm assuming that stands for 'Service Engine Soon'), has been off and on since I bought my 06. I have been told that it is fairly common for it to be harnass related and not necessarily a glow plug? And reading here tells me you guys might know the correct resistance reading for the glow plugs? Would you be willing to share those numbers in this thread? thanks.
