Thread: Starting trouble with 7.3
    Mar 2010
    Default Starting trouble with 7.3
    My dad has a 89 F250 with 7.3 N/A ... truck runs good when you get it runing but the glow plugs wont stay on very long ... wtihin the last 2 years we have put plugs and controler on this truck but only the plugs seem to help much ... he has to use a shot of juice when its 75 out to get the beast going . Im not sure were to go from here with the this Turdmobile
    brian
    1994 GMC 2500 6.5LTD 4wd
    Marine injectors and built 4911 pump to run veggie oil
    1981 Toyota 22L Diesel Pickup
    Sep 2006
    Brooker, FL
    Does it "smoke" white (actually unburned fuel mist) after starting? If so, I suggest replacing the fuel return lines from the injectors.
    Another possibility is a sticky fuel shutoff solenoid - clean the connector and see if that helps.
    It could also be a defective controller; it should power the plugs for a few seconds even at 75°.
    Ether is NOT a good idea with glow plugs.
    Windham, ME
    If the glow plugs are only staying on a few seconds, it means you have a bad plug. Buy ONLY Motorcraft or Beru ZD9 plugs, anything else will be trouble.
    Interestingly enough, though, AC60Gs fit and work in these engines, but work better with a manual setup because the 7.3l controller doesn't keep them on long enough. Wiring in a modified 6.2l/6.5l controller should be pretty easy.
    Here is a thread from another diesel site in which I contributed some info that may be helpful.
    Phil
