So, if you have a 12mm hole that's cracked, wouldn't you want to use the 12mm insert to fix the hole and pull the cracked material back together?
Here is my concern with the logic.
Use the 10mm insert?
If you use the 10mm insert you are indeed drilling the hole smaller to tap for the 10mm hole insert fix.
But?
Part of this fix is to repair the crack as well as give the block good threads for the main caps. I'm not confident that using a smaller insert would fix a hole that started a crack from a 12mm fastener. Would the smaller insert stabilize the crack? Dunno. Ask Lock N Stitch...
Just my thoughts on the matter.
Let's hear yours.
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
