For 6.5 diesel trucks.
I have been machining some fittings that will allow you to upgrade the leaking factory hoses and still continue to use the OEM cooler. This saves you money and why waste a perfectly good cooler.
The fittings match up perfectly to your OEM cooler and have the same oring sealing like the stock hose, on the other end is a male flare. Included in the kit are swivle fittings that allow you to clock the hose where you need it without over tightening the cooler fittings.
Please see this link for pictures and more info.
http://www.pmdcable.com/index.php?ma...hisei18o3gh0u0
I'm making the fitting for both oem cooler sizes. 88-97.5 and 97.5-2000. The HO trucks with 1/2" block fitting will get -10 size hose (5/8") and the smaller coolers will get -* hoses (1/2") Allthough -10 can be had on request.
