Looking at a 2007 GMC 1GTHK23D07F165352
wondering if there anything I need to be aware of?
Thanks for the help.
New user...Jeff
New user...Jeff
Vehicle Information
VIN: 1GTHK23D07F165352 Model: TK25743-2007 GMC SIERRA SLT 2500 CREW CAB 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Vehicle has no current record of required field actions.
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Type Number Description Posted Date
SB G0000083901 Buick and GMC May/June Exclusive Service Offer 05/20/2011
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: U4TAQ0RM XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Diesel Engine Limited Warranty 03/16/2007 185 MI 03/16/2012 100,185 MI
Powertrain Limited Warranty 03/16/2007 185 MI 03/16/2012 100,185 MI
Emission Limited Warranty 03/16/2007 185 MI 03/16/2012 50,185 MI
Bumper to Bumper Limited Warranty 03/16/2007 185 MI 03/16/2010 36,185 MI
Corrosion Limited Warranty 03/16/2007 185 MI 03/16/2013 100,185 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
03/18/2009 177675 ZREG----Regular Vehicle Transaction K5387 - Transmission Fluid Auxiliary Cooler Inlet Hose Replacement 26,487 MI
03/18/2009 177675 ZREG----Regular Vehicle Transaction K5389 - Transmission Fluid Cooler Lower Pipe Replacement 26,487 MI
12/22/2008 175035 ZREG----Regular Vehicle Transaction J6298 - Exhaust Gas Recirculation Valve Motor Replacement 23,429 MI
12/22/2008 175035 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 23,429 MI
12/18/2008 174918 ZREG----Regular Vehicle Transaction J6353 - Module, Powertrain Control - Emissions Related Reprogramming 8/80 coverage 23,258 MI
12/18/2008 174918 ZREG----Regular Vehicle Transaction B9622 - Lamp Assembly, Exterior - Auxiliary Lighting - Replace 23,258 MI
12/18/2008 174918 ZREG----Regular Vehicle Transaction C3128 - Headlining Trim Panel Replacement 23,258 MI
12/18/2008 174918 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 23,258 MI
02/02/2007 309384 ZREG----Regular Vehicle Transaction B0140 - Bracket, Front License Plate Mounting - Replace 202 MI
11/20/2006 A65352 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Vehicle Information
Vehicle Build
Model: TK25743-2007 GMC SIERRA SLT 2500 CREW CAB 4WD Order Number: KMPTZR
Gross Vehicle Weight: 4,177 Build Date: 11/20/2006
Build Plant: F-
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
1SZ - OPTION PACKAGE SAVINGS 3SB - SLE2 DECOR INCLUDES: *6-WAY PWR DR SEAT ADJUSTER *FLOOR CONSOLE W/STORAGE *ELECTRIC REAR WINDOW DEFOGGER *AUTO-DIMMING ISRV MIRROR WITH COMPASS & TEMP *AM/FM STEREO W/CD PLAYER *STEERING WHEEL-MOUNTED RADIO CONTROLS *BOSE PREMIUM SPEAKER SYSTEM *DEEP TINTED GLASS *LEATHER-WRAPPED STEERING WHEEL *CRUISE CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY SYSTEM *POWER HEATED EXTERIOR BLACK MIRRORS *CHROME GRILLE *CHROME-STYLED STEEL WHEELS *BODYSIDE MOLDINGS *ELECTRONIC TRANSFER CASE
41U - ONYX BLACK 69D - DARK PEWTER
69I - DARK PEWTER INTERIOR TRIM 6GL - SPRING COMPTR SELECT FRT LH
7GL - SPRING COMPTR SELECT FRT RH A31 - POWER WINDOWS
A95 - FRONT RECLINING BUCKET SEATS W/POWER DRIVER SEAT ADJUSTER AG1 - POWER DRIVER SEAT ADJUSTER
AJ1 - DEEP TINTED GLASS AM7 - FOLDING REAR SEAT
AU0 - REMOTE KEYLESS ENTRY SYSTEM AU3 - POWER DOOR LOCKS
B30 - FULL COLOR-KEYED CARPET W/MATS B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR-KEYED FLOOR MATS B71 - WHEEL FLARES
B85 - BRIGHT BODYSIDE MOLDINGS C49 - ELECTRIC REAR WINDOW DEFOGGER
C6W - GVW RATING - 9,200 LBS CJ2 - DUAL ZONE AIR COND - AUTO
CMD - ASSEMBLY PLANT - FLINT, MI D07 - FLOOR CONSOLE
DF5 - AUTO-DIMMING ISRV MIRROR WITH COMPASS & TEMP DK7 - OVERHEAD CONSOLE
DPN - PWR HTD EXT CAMPER MIRRORS W/ TURN SIGNAL & LWR CONVEX GLASS DT4 - SMOKER'S PACKAGE
E63 - WIDESIDE BOX PICKUP BED FE9 - 50-STATE EMISSIONS
FT2 - ARM TORS BAR SPRING ADJ FT3 - ARM TORS BAR SPRING ADJ
G80 - H.D. RR AUTO LOCK DIFFERENTIAL GT4 - REAR AXLE, 3.73 RATIO
HVY - IDEN 2 INCH BODY RAISE,HD MODEL JH6 - 4 WHEEL POWER DISC BRAKES, HD
K05 - ENGINE BLOCK HEATER K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER KC4 - ENGINE OIL COOLING SYSTEM
KG3 - ALTERNATOR 145 AMP KNP - H.D. TRANSMISSION OIL COOLER
KUP - THROTTLE CONTROL ELECTRONIC LBZ - DURAMAX 6.6L V8 TURBO DIESEL ENG - 360HP, 650LB-FT TORQUE
MW7 - ALLISON 1000 6-SPEED AUTO TRANS NP1 - ELECTRONIC TRANSFER CASE
NP5 - LEATHER-WRAPPED STEERING WHL NT9 - EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT
NZZ - OFF-ROAD SKID PLATE PKG P03 - CHROME WHEEL CENTER CAPS
PDB - ONSTAR PLUS PACKAGE INCL: *ONSTAR SERVICE - INCLUDES 1 YEAR SAFE & SOUND PLAN *XM SATELLITE RADIO - SERVICE FEE EXTRA-1ST 3 MONTHS INCL. PDN - HEAVY DUTY POWER PACKAGE INCL: *DURAMAX 6.6L TURBO DIESEL V8 ENG-360HP, 650 LB-FT TORQUE *ALLISON 1000 6-SPD AUTO TRANS *H.D. RR AUTO LOCKING DIFF
PY2 - CHROME PLATED STEEL WHEELS QIZ - LT245/75R16/E ALS BW TIRES
R6C - CSV IDENTIFIER R6J - CUSTOMER DIALOGUE NETWORK
R6K - TURN-BY-TURN NOT AVAILABLE R6P - PRICE LABEL PAINT CHARGE
R8C - ******************************* ***** 2007 CLASSIC SIERRA ***** ******************************* R9N - LEATHER SEAT TRIM
R9Z - POMS EXPEDITE-SOLD ORDERS SLM - STOCK ORDERS
T96 - FRONT FOG LAMPS TFE - SALES INCENTIVE-COMMITMENT PLUS
TQ3 - BATTERY 770 CCA (DUAL) U01 - ROOF MARKER LAMPS
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL. UB0 - AM/FM STEREO W/CD PLAYER (REPLACES STD/OPT RADIO)
UE1 - ONSTAR SERVICE: INCLUDES 1 YEAR SAFE & SOUND PLAN UK3 - STEERING WHEEL RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS UQ7 - BOSE PREMIUM SPEAKER SYSTEM
UY2 - WIRING PROVISIONS FOR CAMPER V22 - CHROME GRILLE SURROUND
V73 - STATEMENT OF CERT. U.S. VB3 - CHROME STEP REAR BUMPER
VG3 - CHROME FRONT BUMPER VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL XHH - FRONT TIRE, ALL SEASON
YD3 - BASE EQUIP FOR SCH GVW PLATE YD5 - FRONT SPRING - BASE EQUIPMENT
YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR
YHH - REAR TIRE, ALL SEASON Z82 - H.D. TRAILERING EQUIPMENT PKG.
Z85 - HANDLING/TRAILERING SUSP PKG Z88 - GMC TRUCK NAMEPLATE
ZHH - LT245/75R16/E ALS BW TIRE-SPR ZY1 - SOLID PAINT
Added Option Codes
Vehicle has no current record of SAIO codes.
Thanks GM tech
What happens if I buy a truck with warranty, will the warranty go from build date (11/2006) or from the date shown on the VIN information (3/2007)?
The truck is a repo that I'm looking at and I want to make sure I have warranty for possible problems.
Jeff
3-16-2007. The OEM warranty is valid from the date of first retail sale, minus shop time (full days) and miles during warranty service. Being a repo doesn't matter, the warranty is just as valid. The only thing that can affect warranty claims is post-sale (first sale) modifications (tuner, emission system mod, etc.) or excessive abuse that can cause a denial for a specific claim. No one thing can "void" an entire warranty.
GMCTech, Any way to get the service history and build sheet on the following VIN? Just about to pull the trigger on it and would like to know what's been done, what warranty remains and what's on it.
Thanks!
1GCHK63679F148611
Never mind.
