Results 1 to 6 of 6
Thread: daytime running lights
    Dec 2009
    In the North
    Default daytime running lights
    How do you disconnect the dtrl's on a 94 gmc k2500?
    i want to put on the upgraded headlight wiring harness,. but drl's need to be diconnected,.
    The head light switch is going funky AGAIN,. and it smells hot all the time,.
    Thanks!
    NIck
    1999 chev suburban C2500
    300,000 mi
    Oct 2005
    San Juan Capistrano,ca
    Default DRL Control.
    I simply keep the parking brake down a couple of clicks. No DRL's on.
    4doorTAHOE6.5TD
    Aug 2010
    Pull the fuse.
    2005 Chev K3500 CCLB
    Brighton, CO, USA
    Default Do 94s have DRLs?
    I didn't think 94s had daytime running lights.
    From what I remember, that came out in the 96 model year.
    My dad's 95 doesn't have them.
    Maybe your switch is shorted on?
    Joe.
    Dec 2009
    In the North
    Quote Originally Posted by joed View Post
    Joe.
    well after nearly three years of owning this truck,.*sigh*
    it,s a canadian truck,..
    Quote Originally Posted by racer55 View Post
    Pull the fuse.
    Oh boy do i feel dumb,. i thought it was more complicated than that, DOH!!
    thanks Racer,.
    Nick
    (red faced,. scuffing foot in the dirt,.)
    300,000 mi
    Jul 2003
    Allentown, PA
    FYI - I've been running w/o my fuse for about 6 years, now. If I want my lights on, I turn them on. I don't need a computer to make that decision for me.
