Results 1 to 5 of 5
Thread: Injector return fuel line
    Apr 2011
    Default Injector return fuel line
    I pulled my 6.2 to swap out some gaskets, freeze plugs and hoses. The only 1/8" fuel line I can find is the clear lawn and garden variety. Will that be OK?
    No. That won't work (for long, anyway).
    A complete return line kit from Kennedy (or perhaps other TDP vendors) is $25. The kit is an injector service kit and includes all the lines, end plugs, injector coppers and air cleaner gasket, IIRC. If you want only the hose, contact him. I don't know if he sells it separately, but might.
    Apr 2006
    Cedar Grove, NC
    Quote Originally Posted by woodwright View Post
    I think I would look up a diesel shop in the phone book and give them a visit. I expect that they would have a spool of it and could sell you what you need + the clips if required with the particular type of hose that they use.
    84 C10 J code intake.
    83 C10 Scottsdale w/veggie conversion.
    98 K3500 Silverado CC DRW, marine injectors, 4" exhaust (kitty cat MIA), boost and egt gauges, FSD relocated, #9 resistor thingy, reman Navistar block from Kennedy installed Jan 08, Reese Signature Series Gooseneck hitch.
    95 C2500 F code. Rebuilt GEP. Daily driver since Jan 2014.
    Sep 2006
    Brooker, FL
    Most NAPA stores stock it, as a kit of precut hoses and clamps.
    You can find it on ebay.
    Here is an auction number 270659537940 at ebay
    This is the stuff I got, its made in Germany and is a Push Lock type hose. Very good stuff
    The stuff you want has a fabric cover and does not require clamps, except the rubber stoppers on the back end two nipples.
    I bought some for the DaHoooley engine and it was great stuff.
    Good price too
