steering wheel abnormal play
Hi,
My steering wheel has a lot of play if you move it from top to bottom (lets say around 1/2") and about half of that play from side to side (1/4"). There is no play if you try to move the steering wheel in and out in relation to the steering column. Searching the forum there are posts about 4 bolts coming loose inside the column, is this my problem or is it the tilt mechanism going bad? Eventually will either of these items become a safety factor?
Thanks.
3ace
1991 Suburban 6.2L 3/4T 4X4 Banks Sidewinder Turbo Frybridized
