Thread: Head bolts
    Sep 2003
    Feeniks, Aridzona
    I am looking for new head bolts (studs actually) for my 6.5. The application book only lists them for a 6.2. Question - aren't the head bolts the same between the 6.2 and 6.5? Thus, studs for a 6.2 should also fit a 6.5.
    eracers999 Guest
    Same Same, can you still get the heads off with the engine in the truck if you have studs??
    Kent
    Sep 2003
    Feeniks, Aridzona
    Thanks. And yes, you can remove the heads - you just have to remove the studs first.
