The little coupler on the Xover (RH side) has a restrictor orifice in it, and this could have issues.
Getting the aluminum pipe out requires that you retract the little lips on the plastic insert and slide the pipe out.
Now, you are already up to speed on these things, yesss they break off in the xover and are a bitch to get out.
If you do break it off, DO NOT despair, the Xover can be salvaged easily.
You simply remove thye Xover get it out where you can see what your doing, then using a die grinder relieve the aluminum from the inside of the coupler on opposite sides (make a little groove the length of the coupler part thats broke off)
Once you have a little groove on opposite sides that just starts to show the threads of the Xover port your good.
Now you take a small capeing chisel and small hammer and peal the offending part inward and away from the threads in the Xover.
This may seem like a tough task, but I can usually manage to extricate these within 15 minutes or so once the Xover is off and on the bench.
Once the broken part is out, run a Pipe tape (1/2") through the threads to just clean it out.
Install the steel version of the coupler from NAPA or ??? parts house and your good to go.
Smear some Hi Temp RTV on the threads before installing the new coupler.
Good luck and keep us posted
Missy
