TH-350 Identification
Could any of you transmission gurus help me with the following TH-350 transmission codes? Here is what I have found on the transmission. I am having trouble identifying it despite having the TH-350 Handbook by Ron Sessions.
The area where the VIN from the donor vehicle would be stamped is broken off. Here are the codes:
Converter Housing: Q1; I don’t know what this is.
Pan: B5H19D; I know that this is a Parma built transmission, built on June 19, 1975, Day shift.
Pan Rail (Front of Transmission); C1806 500 6; I don’t know what this is.
Inspection Cover Area on left side of Transmission: 15C255373 or 15C255378 (not sure about last digit). I don’t know what this is.
I am trying to find out what the original combination was for this unit, if at all possible.
I believe it was a car application, because it is a short tail TH-350.
Thank you for any help that you may be able to provide.
1993 Suburban 2wd 6.2L Diesel Conversion "Andromeda":
3.73:1 gears, THM 700-R4 transmission, and
J-code 6.2L diesel from a 1984 C2500 Suburban
1996 2wd to 4wd converted Ford F-150 300ci Inline 6 "The Argo" 336,000 miles and climbing
1992 Caprice Wagon 5.0L V8 "Enterprise-D"
"Ah ha ha ha! I swear! Tractors is so dumb!" - Mater
"The Argo? That ridiculous pile of scrap metal!"
