That is good info to know - thanks for posting!
FYI - there's a couple ways you can find your (or anyone's )previous post.
Since you don't have many posts, just click once on your name (in any thread) and select "find all posts".
Or, do an advanced search and use your "handle" as one of the search criteria. Add more search criteria to narrow the results.
Or, just go into the particular forum that you originally posted in and scan the posts until you see yours.
