This is going back a few years, but the same thing (hard to open, eventually broke) happened to my dad's truck. I got a new inside handle assembly from NAPA (maybe a dealer... don't remember). I think it was about $35.
For the hard to open part (again going from memory), I believe it was the little plastic piece that connects the steel rod (from the inside handle) to the latching mechanism. It was weak/partially broken.
