Results 1 to 7 of 7
Thread: Mileage burning #1 vs. #2 diesel
    Default Mileage burning #1 vs. #2 diesel
    So...I have been under the impression for some time that the BTU content of these blends are the same. However, on the occasions that I have filled with #1 diesel in warm weather, it seems that my average MPG on the DIC begins to climb.
    Yesterday I drove unloaded about 180 miles, filled and realized I put in #1 diesel. On the way home, same speed, I added about 1mpg to my average.
    Coincidence? Factual? Maybe a tailwind on the way home, instead of a headwind?
    Jul 2003
    Allentown, PA
    Well, Mark, now you've got me scratching my head! I had always thought that the (very basic) difference was that #1 had slightly less BTU's, but also does not gel as soon. ???
    Jul 2011
    Kansas
    I was under the impression that #1 had less wax in it so it could resist gelling better at lower temps. With the lower amount of wax came lower BTU per gallon.
    I am sure someone will chime in and set the record straight.
    Brian
    1995 GMC Surburban, 3.42 gears, 4in WarpSpeed Exhaust, Remote PMD, Airdog-100 Lift Pump, Racor fuel filter/heater, S&B cold air filter setup, P-400, ATT, and a Heath tune! SOLD all that after putting 3/4 million miles on that rig! Now drive 2015 ram EcoDiesel.
    Dec 2002
    Teton Valley, Idaho
    the Mercedes forum, Dodge forum, Cummins forum, and some others say:
    less BTU's/gallon (137,000 vs 142,000? ish), less paraffin so won't gel as soon, less lubricity because of less wax, costs more, poorer mileage.
    Methinks you had a tailwind...
    I think it was a tailwind, and a lighter foot on the way home. Average for the 400+ mile day was 19.2mpg unloaded. Not bad!
    Jun 2007
    Watkins, CO
    On my 2003, I see a noticeable drop in mileage (2-3 MPG) between November-February when they sell the winter blend diesel here in the Denver area.
    Bob
    tufcj
    Hard to gauge what effect it might have for just one tank of fuel, but #1 has less fuel lubricity and can increase fuel injection system wear when used in warmer weather. Here in Montana, we get winterized fuel (mix of #1 & #2) through about April 1st, and am always glad when the pump indicates straight #2. Jim
