Originally Posted by
wpdozer
So the question is- Will this servo remedy some of the irratic behavior prone to this transmisson? I really don't like this trans at all
. HELP!
Yes it may remedy the erratic (shift flare) behavior you described. But make sure your TV cable is set up tight enough. What year 700R4 is in your truck? The 1987 and newer 700R4's were much improved. The original 1982 700R4 in my Suburban had the same symptoms as you described and it literally exploded about a week after I installed exhaust headers for more power so I ended up installing a newer 700R4. I'm like you, I don't like this transmission. That's why everything except this Suburban has been converted to manual transmission (NV4500 or NV5600).
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
1982 ½ ton Chevy Suburban
-Stans headers
-Ported heads
-Timing gear
-4 speed automatic
-3.08 gears
-30 mpg on freeway
