Thread: Need A6 Compressor Front Support Bracket (82-84 Pickup)
    Jul 2012
    Crestview, Fl
    Default Need A6 Compressor Front Support Bracket (82-84 Pickup)
    Hey guys, I am about 95% complete on putting a Vintage Air "SureFit Gev IV" AC system in my 82 GMC K2500, 6,2 Diesel, pickup. Unfortunately, they do not make the AC compressor brackets to mount the new Sanden compressor and I threw away the old A6 compressor brackets years ago. Couple of issues here:
    1) I got the adapter conversion brackets for the Sanden compressor, but they require the original A6 compressor brackets to mount to!!!!!
    2) I was able to find a good source for the original A6 brackets, you can find these at http://parts.nalleygmc.com/showAssem...roduct=2681922 .
    3) Last piece of puzzle missing - The original bracket source from "Nalley GMC", has all the brackets except for one.
    Bottomline:
    I need the front A6 compressor support bracket, here is the description:
    "SUPPORT. AIR CONDITIONING (A/C) Compressor Mounting, stock code 14033864"
    I hope this helps anyone going thru this. I am restoring this truck, and this is my only snag so far.
    If anyone has a source for the above bracket, would really appreciate the help. Like mentioned, you can get the rest of the brackets from Nalley GMC, however, this last one has been discontinued by GM and is no longer available.
    *1982 GMC K2500 "High Sierra", 6.2 J Diesel(stock), 3.78 rear, 700R4 Auto Tranny, 4wd, 2dr long bed.
    *1998 Dodge Ram 3500 Quadcab, 5.9 Cummins 12v(modded), 3.54 rear, 47RE auto tranny, 4wd, long bed.
    Aug 2003
    Bakersfield, Ca
    Default Part 13
    That part has a couple of jobs. The front A/C adjustor bracket attaches on it. The power steering pump bracket is attached to it, and the PS reservoir bracket slips in behind it. I've seen a couple of these brackets in the pick your part, and they generally are cracked.
    HammerWerf
    1999 k2500 Suburban Pyro, Tranny Temp, Boost, K&N Air Filter, +3.5 qt tranny pan. 190000 miles
    1984 C20 249k miles DSG gear, SM-465, 3.73
    1983 C30 CC dualie. 308K miles on Chassis, TH400, 4-45 A/C Looking for a TurboCharger
