HELP lighting issues
My 98 gmc c2500 vin F is having some issues with brake/turn lamps. Both front turn signals work, and both rears work. When signaling right the lights flash fast like I've got a bad bulb. They flash normal when I turn hazards. Left brake light does not work but right does. Also right front headlight works intermittently.
I have changed all bulbs and both tail light circuit boards. I swapped known good brakelight switch with no change. I have checked connectors and applied dielectric grease to bulbs and connector contacts. I know both circuit boards are good I swapped sides and the problem did not change. I feel like it may be the turn signal/multifunction switch but hate to spend almost $200 on it to find out. Does anyone have any tips or suggestions as to what the heck I should do at this point? Any input is appreciated.
Will
1996 GMC Suburban, 6.5 TD, 4L80E, 3.73 Full floating limited slip rear end, 285/75R16E Dayton Timberline ATII's.
