Thread: 91 V2500 Burb Fuel Filter
    Dec 2012
    DeFuniak Springs, Florida
    Default 91 V2500 Burb Fuel Filter
    Has anyone eliminated the Stanadyne Model 80 fuel filter and gone to a different filter system? Or does anyone have solution to leaking problems around fuel heater?
    Nov 2008
    So. Cal. USA
    You probably need to replace the o-rings around the fuel heater element and the plugged filter sensor. They pull out and you can get replacement o-rings. Check the 2 small seals in the water drain petcock bore on the bottom of the base and the air purge petcock on the top of the base. You can still get them but are expensive.
    Feb 2008
    Northeast CT
    I used a FFM off a newer 6.5TD. So far so good.
    1886 M1008 CUCV
    GM4 Turbo,DB24911 turned up.
    Raptor 100 lp.
    5 inch Redneckmaster Ex
    Autometer Fullsweeps
    Previuosly owned:
    2000 K3500 6.5TD
    1993 K3500 6.5TD
    1983 K5 6.2
    1998 GMC Suburban 2500 6.5TD
    1991 GMC Jimmy 6.2
    1983 GMC K2500 6.2
    1999 Ford Suerduty 350 7.3PS
    1983 Ford E-350 6.9
    1982 VW Rabbit Diesel
    Dec 2012
    Default filter replaced
    I took the old stanadyne and trashed it. Replaced with a new 6 micron spin on filter. Works perfectly and I do mean PERFECTLY! So dont hesitate to replace the old stanadyne when yours fails
