Results 1 to 6 of 6
Thread: Solid Axle Swap Info?
    Aug 2010
    Vancouver WA
    Default Solid Axle Swap Info?
    Anyone have a good link for a complete write up or how to forum for SAS swap in a 98 ish k2500 6.5 diesel?
    Looking into the idea and wanted to get a feel for difficulty and cost...
    Thinking about a 8 lug 10 bolt front, cut and swap for a drivers drop pumpkin...
    Ideas?
    Thanks
    Mike
    The ones I keep hearing mentioned are the ORU kits: http://www.offroadunlimited.com/orus...p?idCategory=3
    No personal experience with them, though. Personally, with the 3/4 ton diesel, I'd be looking at a D60 over the 10-bolt.
    Diesel Page Member #2423
    Dec 2006
    North Pole, Alaska
    Definately go for a D60, and using a 88-96 Ford front axle (driver's side drop) would be easier as you can use your current Transfer case. Also would allow use rims with the 8x6.5 bolt pattern.
    Aug 2010
    Vancouver WA
    Quote Originally Posted by AKMark View Post
    How do i solve the ABS issue? do any on the straight axle candidates have ABS?
    Thanks
    Mike
    If you read the ORU info, they recommend contacting Dynatrac. They offer ABS on their axles and can possibly help retrofit other axles.
    Oct 2011
    Northeast GA
    I put discs on the back and done away with the ABS. Go to offroaddesign.com, their single axle swap stuff is what I used.
    An axle from a 1978-1979 F-250 (HD Dana 44) or a F-350 (Dana 60) work well as they have the spring perches in the right place. They are also high pinion axles. Both are 8 lug.
    It's not a hard job you just need to have it all planned out before you start.
    1992 Suburban, J-code 6.2L from CUCV, 700R4, NP241
    9" lift with straight axle conversion, HP Dana 44 with Loc-Right in front, Dana 60 with Detroit in rear, 4.10 gears
    37 x 12.50R16.5LT HUMMV tires (rolls out at 35")
