Cooling system pressure is normal and is caused by expansion of coolant as it warms up. When it contracts it should come back to normal.
If there is pressure remaining when cooled then you are adding something from somewhere.
If there is a vacuum the upper hose will collapse and that just tells you that something escaped plus the cap did not vent inward properly.
