I've had a delightful time with my Duo-Therm Penguin II. I wanted the manual (non-electric) shroud-mounted thermostat; after the third failure I replaced the shroud (different shroud for each!) and had the remote analog electric installed.
I'm on my 3rd remote - the original eventually couldn't hold a temp, the second just didn't work, and the last one turns on the heat strip and compressor at the same time, whether on heat or cool.
This thermostat is being phased out for digital, which naturally needs a different control board.
Fortunately, I took the extended warranty...
