What worked for me was using a flywheel: casting# 14050525N with everything else from a 350 making sure the distance from block/ bellhousing split to clutch face of the flywheel is the same for both engines and the 350 pressure plate being able to bolt up to the 6.2 and also the clutch splines matching the input shaft, it should make the linkage adjustment be close.
