What type of antifreeze is in it? The orange stuff will actually mix with oil and form a goop that will stick to the inside of everything. if you don't get rid of it, it will eat your bearings. I would change the gaskets, refill, run it to op temp and then use an oil flush product and change the oil again then change that oil out after about 3-500 miles. Might be overkill but oil is cheap and bearings are expensive. If it was mine I would do that no mater what type antifreeze it was but for sure with the orange stuff.
Good luck
Hope this helps
2001 Chinook RV, V10 gas
1967 GTO, 1989 Honda Transalp
3 kids, 1 wife, 1 dog
