Results 1 to 15 of 15
Thread: dual batteries
    Apr 2014
    Canada, Northern Ontario
    Default dual batteries
    This is my first post here. I searched for the duel battery topic but I didn't find what I was looking for.
    I 've had to boost my truck a couple of times the last few days. I had 1 battery on the charger over night and now when I check to see the charging rate with my multi meter, the drivers side battery( which was charged over night) is charging at a rate of 13.8 volts and the other battery is charging at 12.6 volts.
    Is it time for new batteries or alternator?
    Jan 2006
    Boissevain, MB., Canada
    New batteries
    '95 GMC K2500, "Bullet"Ex. cab short.4X4, 377,000kl on truck, 177,000kl on AMG engine, auto. 3:73 Ltd. slip, FSD remote mount, OPS relay,AFE air IN, Kennedy 3 1/2" OUT . '83 F250 HD3/4 " Robert The Red Ford"4x4 460, 3:55'posi . 2005 GMC : G WHIZ" crew short box, 5.3, 4:10. , '88 Bronco II 4X4, '95 141,000kl Ford F150 EX. short box, '92 "Toy" 4 runner 273000kl ,'63 Mercury 45000miles !!!! Auto insurance co. is my mistress !!!
    Apr 2010
    Sounds like a bat on its way out.
    Pull 'em both out and have a local garage load test 'em for ya.
    Of note: a bad bat connected to a good bat with kill the good bat in fairly short order.
    Get 'em checked....
    1998 k2500
    Apr 2014
    Will do. The problem is partly because I didn't change then both at the same time although it wasn't supper long between from one to the other. And the other thing is they are both costco batteries.
    I looked into new batteries last week and the best batteries I can get here are Oddesy AGM batteries , but they are $250 each. The next best are $180 each.
    Madison, AL
    Exclamation cables
    Also check the condition of the connecting cables between the batteries and to the ground points. Corrosion can sneak into the connectors junction to the cables and be very hard to see unless you actually probe the insulation at the connection. (personal experience)
    WAM, 2500HD D/A ext cab 4X4, 1997 Suburban 6.5TD K-1500.
    The ground cables and the crossover cable are notorious for failing
    bmoeller has it spot on.
    The cables corrode deep inside right at the terminal ends and so do the grounds.
    Nearly impossible to visually inspect
    What year is the rig ?? cables original ???
    Missy
    Apr 2014
    It's a 96 and as far as I know the cables are original, although they don't look too bad
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    I have had GREAT luck with both Interstate batteries and Optima. I had a Odyssey in my Motorcycle and will not be buying another on of those. Personally I would buy whatever brand you can get with good local service and warranty.
    If you are at all handy with electrical stuff go out and buy yourself some heavy gauge welding wire and make up your own cables. Make sure all the crimp connections are clean, sealed and TIGHT.
    The cross over cable is a huge draw and basically turns into a great big resistor over the years. This tends to act like a low(or BAD) voltage battery and will eat your other battery. If you don't replace them at the same time you will most likely not be happy. I even try to get two batteries with the same date code. I have three vehicles with two batteries and 4 others with singles. So when one starts acting up the bad battery goes for the core and the good one gets rotated to whatever has the oldest battery.
    Hope this helps!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Ironically, your misspelling is the heart of the problem. As one of the dual batteries goes bad, the batteries start to duel until they're both bad.
    Diesel Page Member #2423
    Apr 2014
    I am a welder buy trade and a couple of years ago became a red seal millwright as well so making my own cables won't be a problem. Was the odyssey a AGM type? For now my battery problem has to take a back seat, I'll start another tread for the other issue I'm dealing with
    Feb 2003
    The Odyssey was a sealed dry cell made more for airplanes and then adapted to motorcycles. Their AGM might be a better battery, still not sure if it would be worth the cash. I had two red top optimas and the lasted 6 six years. I had two car-quest AGMs that lasted 5 years. How long is the truck going to be in service? I think just about any reputable AMG or gell type battery would be a good bet.
    Apr 2014
    I need a truck for the foreseeable future and if I decide to rebuild the engine then even longer
    I have/use Optima Yellow-Tops. Going on 10 years now in my 2001, still as good as new. Expensive, yes, but 10 years on a battery(ies) is nothing to scoff at.
    Always replace them as pairs. As said, a bad battery will kill a good one, when connected in parallel.
    16gaSxS is offline Moderator, Have Shotgun & dogs will travel
    May 2002
    Great Falls, MT
    Default Rotate Your Batteries!!!
    A buddy who's a Top notch Aircraft mechanic (A&P AI) told me a number of years ago to rotate the batteries once a year and I would get longer life from the pair. I buy inexpensive batteries from a local Battery vender and in the fall I stop by for service and have them rotated my average battery life increased 2-3 years just by doing that. They think I'm nuts but it works.
    95, 6.5, C-2500 extended cab shortbox, Auto transmixer 3.42 diff, Jardine exhaust system
    FSD Cooler replaced w/ Heath PMD Isolator
    Heath Turbo-Master Boost Controller, Max E Tork chip '97 cooling upgrades, Kennedy Fan clutch,
    Glow Plug over ride,DeeZee 38.5 gallon Aux fuel Tank 225K miles and rolling
    1994, 6.5 Blazer, 3:42 diff, 4 inch exhaust, Heath PMD Isolator, Heath Turbo-Master Boost Controller Max E Tork, Heath SB intake filter system.
    221K miles and rolling.
    Diesel Page member #81
  15. #15
    Apr 2014
    Thanks for the info.
    I'll swap my this weekend
