4L80E No Shift problem
1994 P-30. 6.5 TD Motor Home.
Randomly the trans will not shift after a start. I'm not sure if it is first or second gear (second is default I believe). After shutting down and restarting all is ok. It stores codes 74 and 85. Has done this twice in the past few days. I just checked the codes and they are not there. I did replace the input speed sensor as a stab in the dark and I think the codes were in there before that, but I might be confused. Sorry for the not so clear description. Just thought that this might be a condition that someone has run into.
Bill Carry
Bill Carry
Sylvan Lake Michigan
'94 Georgie Boy Swinger 30' motor home
6.5 TD front engine P-32 Chassis. GEP 400 replacement engine at 176000K.
Stock except for remote PMD (inside the air conditioned motor home)
Boost, EGT and Trans temp gage 260000 miles as of 10-14-19, all mine.
