Knock cold idle
I recently started hearing a knocking noise shortly after starting my 07 LBZ 120K miles (Florida cold start). It sounds like its coming from the top end and it sounds like a small engine rod knock. It goes away just above idle speed and when it warms up. I do not hear it at highway speed or under a load. The oil has been changed recently and is at the correct level. The oil pressure is about 40 psi at idle and 60 psi at speed. Other than the knock it idles/runs fine, no skipping or loss of power. Ideas? Thanks in advance.
2007 GMC SIERRA CLASSIC
6.6L LBZ 136,000 miles
Diablo Sport Predator Tuner (MPG Tune)
LT245/75R16E
"Just because you are unique, does not mean you are useful."
