Results 1 to 2 of 2
Thread: A/C Condenser Fan wiring diagram
Hybrid View
    Jan 2005
    La Mirada, Cal
    Question A/C Condenser Fan wiring diagram
    Hello,
    I'm trying to help my A/C cooling efficiency on my 94 sub by installing a A/C Condenser Fan Assembly. My rig didn't come with either an auxiliary electric fan or a condenser fan but it seems it was an option.
    The unit i purchased bolted right up to the factory holes but I can seem to find figure out the wiring. I have an "extra" plug in the general area but the plug doesn't match the fan plug. The wires on the truck plug are green and black? I would like the fan to turn on when the A/C system is on..I was told by an A/C mechanic that this would help cool things down while in traffic.
    If this fan were an option, wouldn't the wires / relay be in there somewhere.. thoughts?
    thanks...
    04 GMC Sierra, 4x4
    94 suburban, 4x4
    84 suburban, 6.2 with Banks. Turbo 400 w/4.10's. Ex-Fire truck.
    83 Volvo 760 turbo diesel. Yea it's ugly, but it gets 40 mpg on the highway...
    Oct 2015
    Anson
    Can you check the plug in question with a volt meter? Check with ac off, then with it on. If you get voltage with it on wire it up! you can get your own connectors if you want.
    1993 6.5TD 2wd Ex Cab
    Nv4500 manual trans
