Results 1 to 4 of 4
Thread: New Member
    Jan 2016
    savannah ga
    Default New Member
    Hello to All, My name is J.R. and I live in southern Ga. I have been a heavy equipment field tech for several dealerships for about 30 yrs. Recently I purchased a nice 95 with the 7.4 to pull a 32'' camper with and shortly thereafter found a one owner 94 k3500 with a blown 6.5,which while exploring repair options, led me to this website.Here's a couple of pic's of the trucks and I will be looking forward to gaining knowledge from this Forum. J.R.
    Welcome!
    Those are some sweet trucks! Do you know what is wrong for sure with the 6.5L?
    Jan 2016
    savannah ga
    Yes'sir ,The top of the #8 bore has a crack about 1/2 long parallel to the deck.engine ran but compression into coolant.i am looking for another engine,perhaps a good block to rebuild. J.R.
    Cracked #8 bores were more common in the 97-99 trucks.
    Unit had an engine swap at some time???
    Find a decent block and swap everything to it.
    Been down this road a few times with these lovely Dahooooly trucks.
    Good luck and welcome aboard
