Results 1 to 20 of 20
Thread: Researching 4L80E to NV4500 Transmission Swap
    Default Researching 4L80E to NV4500 Transmission Swap
    I’ve never been much of a fan of automatic transmissions. That largely comes from driving my parents’ 1974 Peugeot station wagon as a teen. I’ve never personally owned a vehicle with an automatic until purchasing the 1994 Yukon in my signature (you can find more details about it HERE). I’ve always liked these two-door SUVs and found one at a price I couldn’t pass up - but I’m pretty sure they never came with a manual transmission.
    Half a year of driving it hasn’t warmed me up to the automatic any more, so I’m looking into swapping an NV4500 into it. The first issue I run into is that of the ECM.
    On the one hand, I see information like that from this site: The Novak Guide to the GM 4L80E Automatic Transmission
    All 4L80E transmission use electronic controls; typically from the Powertrain Control Module. […] The Transmission Control Module (TCM) is an adaptive learning, computer integrated into the valve body of the transmission and communicates with the Engine Control Module via the onboard vehicle CAN bus network. This is both a return to and a departure from previous automotive control systems in the industry in that earlier electronic transmissions used a separate control module, later to be integrated into the Engine Control Modules which were thus termed Powertrain Control Modules. Now, the high-speed CAN network allows a high rate of data sharing between the units to achieve a collaboration between both engine and transmission functions.
    (highlights mine)
    But then I’ve also seen information such as this post: Transmission swap to NV4500 This is how I did it
    My truck is a 99 K3500 6.5td Crew Cab. […] Anyway several people have asked me for details on my trans swap so I thought I would post it so that others could get the info.
    I got my NV4500 from a 4x4 accessories company out of Alabama that I found on the internet. They were easy to deal with and I got a brand new NV4500 for $1910 delivered. This was not much more than I could get a rebuilt for.
    My bell housing, single mass flywheel, through out brg, concentric slave cylinder and master clutch cylinder came from another diesel page member that only had a 6k miles on these parts. I gave $450 delivered for this. My other option I was considering on these parts was to buy a new clutch from Kennedy or Heath which when I checked one of them had the clutch and flywheel parts for $384. The rest of these parts I was trying to find from a salvage yard but manual parts are hard to find.
    I had to buy the clutch pedal and bracket from a local dealer that gives a substantial discount on parts. These cost me about $100. The pedal, master, slave and bracket has to come from a 97 or newer. The older ones are a different style.
    I got the shifter stick and boots from a salvage yard for about $20. They were from an early 90
    (again, highlights mine)
    The one thing I notice is no mention of computers… Even with a newer OBD-II truck.
    So, my question is whether the 4L80E in my ’94 Yukon is “talking” to the ECM or not? If the 4L80E is just separate, swapping it out for the NV4500 should be a “mechanical” project. But if the ECM is going to be “confused” when the 4L80E disappears, then the project becomes an “electrical” one and the ECM will have to be be reflashed with the programming for the manual transmission or swapped for one from a manual transmission truck.
    Can anyone answer which way it is? Or point me in a direction to get the information I need?
    Sep 2006
    I may be wrong but I believe it's the 4L80E that becomes confused if disconnected from the ECM.
    I've got a 1996 2 door Tahoe with an NV4500 swapped into it. A few things to watch out on these transmissions is the synchros going out often from the wrong type of oil used. Another thing is the 5th gear nut falling out but usually from a high torque, low rpm engine. Overall, I'm like this transmission but the gear spacing is pretty wide if you're going to use it for towing.
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    I’ve got an NV4500 in the K2500 and am pretty familiar with its idiosyncrasies. The “mechanical” part of the swap doesn’t worry me too much - just the electronics. So the 4L80E “missing” the ECM (such as in a mechanical injection swap) isn’t a problem for me. I’m just concerned about the ECM wondering where the 4L80E got to…
    Sep 2006
    I might be wrong but without the 4L80E in there, the check engine light might illuminate. That would be a concern if inspection in your area requires the CEL to be off.
    -3.73 gears
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    We do have annual inspections here, so a CEL would be an issue that would need a resolution.
    Any idea where the connection between the transmission and the ECM would be? Would it be a plug into the ECM? Or a connection in the wiring harness someplace?
    I wouldn’t expect the 4L80E to work properly if I unplugged things, but I could see if the CEL comes on or if any codes are set.
    Sep 2006
    There should be a connector that plugs into the transmission itself. However, the CEL may not show up until it is being driven and only under certain driving conditions. The ECM monitors torque converter slippage and it'll throw a code when it notices the converter not unlocking.
    The fix is to find an ECM out of a manual transmission truck with the same engine and same year. Ebay would be where I would start looking.
    Thanks for the information. Just seems strange that people aren’t mentioning the computer part of the swap.
    Sep 2006
    I did a search and did find someone who did this swap and had to swap out the ECM to clear the CEL. Other than that, I suspect many just pull out the bulb on the CEL.
    Looking at Hypertech’s chips, they do LIST separate chips for automatic vs. manual transmissions.
    Near as I can figure out, you need the PROM and possibly the CALPAK from a manual transmission vehicle to plug into the ECM - or the whole ECM with the proper PROM and CALPAK.
    Unfortunately, it looks like you have to physically change the chips as the early ones aren’t able to be reprogrammed.
    Ok, it looks like I have to track down a ECM or PROM and CALPAK from a truck with a manual transmission to make the swap. How close does that have to be? Any K1500 GMC with a manual transmission - pickup or SUV? The pickups are rare enough with a stick - I’m guessing the SUVs are unicorns if they even exist.
    And am I limited to GMC? Or would a Chevy version work?
    They are one and the same, features for features.
    Thanks, Maverick. Does the pickup ECM work or is there anything specific about the SUV version?
    Simply, it will work as-is. However, because it's a SUV, it may have some features that are ECM dependent not present on a pickup. Much depends on the year model and optioned features. There are no manual tranny SUV's, so there will be no out-of-the-box solution. If you just plug it in and run it, you will see a continuous SES lamp, and may be forced into limp mode (not at a time of your choosing).
    I do not recommend "pulling the bulb", as the SES lamp is a diagnostic tool that will alert you of other, more serious issues that may lead to damage, or worse.
    What I would suggest......
    Keep It Simple (and probably less expensive, all told). Contact Kennedy and purchase a power chip. He can adjust the program to eliminate the transmission monitoring (and other annoying EPA required features), while remaining specific to your model. A little boost in power and economy would be an added bonus.
    Ok, that makes sense. I was starting to see my search for an ECM to swap in becoming a lost cause. Most of the ECMs on eBay say to swap in your current chips - or just give a part number and say that you’re responsible for determining if it is an applicable use.
    The other option would be to do the MFI swap. That would eliminate all the electronics...
    What all are the differences between a Turbo and a NA MFI 6.5?
    I know the Turbo uses the short body injectors for clearance and that the precups are different, but are there any other major differences?
    I have a line on a parts truck with a NA MFI 6.5 in it. My thought is to use it for an MFI conversion for the Yukon, so I’d mainly be looking at stripping off the MFI components from the donor engine to transplant onto the Yukon engine - IP, lines, and front timing cover. But I’d keep the turbo that’s in the Yukon.
    I’m also looking to swap in an NV4500 so that I don’t have to deal with computer issues with the 4L80E.
    It depends on the chassis model and year. All van and many step van chassis have a different upper engine. The injector angles aren't the only thing. The heads and intake will be different (60 vs. 90* bolts). I've not seen it done, but I don't think you can use your current turbo config. Van and most chassis are center mount.
    Would a van or chassis engine affect the IP and lines? I guess it would affect the lines due to the injector angles?
    Yes. They require different injector lines. The difference is significant, so slight modification (which shouldn't be done, anyway) is not an option.
    Sounds like I should keep looking. Thank you for the advice.
