I need new hinges for my 96 and also a new door latch mechanism what year will fit my truck ? The parts houses want 150 bucks for the latch so I was hoping to find one at a junk yard .
Thanks Shaun
Thanks Shaun
1996 k2500 extended cab automatic trans electric shift transfer case reman engine with 70,000 miles reman trans 60,000 miles
Howdy
In my experience, re: hinge pins, unless you can find a known newer one in a yard you will likely have the same problems with any used parts.
My neighbor is a salvage yard and he sells new hinge kits and latches.
The cost is high and the hinge pins are a pain to replace but most of the new kits are better than what the trucks came with.
Hope this helps
2001 Chinook RV, V10 gas
1967 GTO, 1989 Honda Transalp
3 kids, 1 wife, 1 dog
Thanks for the reply a freind stoped buy today and gave me a new latch so I've got the door so it'll open and shut now still debating on hinges becuase they are welded to the body I might just try putting a new pin and bushings in it
I just completed swapping both pins and bushings on drivers side. Accrual hinges were fine and the dorman hinge pin kit worked well.
Spring was a pain but I compressed it in the vice and locked it with tie straps. Have a helper for the door weight. I had trouble managing on my own and wifie had to help out.
